Brake drum balance.... - Vintage Mustang Forums
post #1 of 8 (permalink) Old 12-27-2012, 07:59 AM Thread Starter
Mustang_zulu's Avatar
I always had a vibration in the car at high speeds. Swaping entire drive train I still noticed it. I went and replaced the original driveshaft with one made by Denny's. Taking her up to 120 is not a problem but I still notice a small vibration like a wheel is not balanced but all my wheels are are new , new tires, computer balancing... Whenever I take the wheels off I notice weights on the brake drums (i have 4 wheel power drum). What are the chances i would feel vibrations from the brake drums? I have my 4 wheel disk conversion here to install so the drums will be gone soon... What do ya think??
1968 Coupe, forged roller 408, AFR 205's, custom Comp roller cam, FAST EFI 2.0, Headman headers w/ full stainless steel Flowmaster system, FAST Dual Sync Billet ignition, MSD Blaster coil w/ CDI box & rev limiter, Holley elec fuel system, PA C4 w/4000 stall, Ford 9 inch (Yukon bolt through case w/ 4.11, Billet Detroit locker, 35 spline forged axles), NOS, MT ET Streets, Denny's Alum Drive Shaft.
Mustang_zulu is offline
post #2 of 8 (permalink) Old 12-27-2012, 09:40 AM
charlie65_67's Avatar
I think it entirely possible a slightly out of balance drum could create what you describe.
It is also possible that tires/wheels that were not lug centric balanced, or an out-of-round tire could cause the same thing.
Given your soon to be conversion to 4 wheel discs however, it is an issue that needs to be addressed after the conversionn is finished.
Charlie, CMSGT USAF Ret. 65 Hi-Po F/B, Mustang Owners Club of Austin (MOCA) TX, Member MCA #27479. Now working a '69 M code mach 1.
charlie65_67 is offline
post #3 of 8 (permalink) Old 12-27-2012, 10:04 AM
sixtysevenGTconv's Avatar
You don't say if vibration is there when just braking or just running on highway. My experience is when braking while at highway speeds is (as schooled by our club master mechanic) if your vibration is felt in steering wheel while braking then front drums our rotors need to be turned. If when braking on highway and you feel vibration in chassis on in seat it's the back drums that need to be turned.
If you're having a vibration while driving highway speeds (not braking) then tires/wheels, front suspension, trans or engine mounts broke or weak, maybe flywheel, drive line angle if changed from stock, U joints, driveshaft not balanced, maybe trans rear bushing worn. Those are a few things possible NOT related to brakes. Not easy to nail down. Gotta rule each out.
If you borrow a tool more than twice, you need to own it You get what you pay for!
George email: <myhawk@gsinet.net>
sixtysevenGTconv is offline
post #4 of 8 (permalink) Old 12-27-2012, 12:40 PM
Joe
It is very possible. I had a vibration on my '72 that appeared at around 60mph, and developed into an outright shaking by 75mph. This happened immediately after all new brakes were installed. It turned out that one of the new drums was out of round - you could see the wobble when it was put on a lathe, but it looked perfectly fine otherwise.
'65 Coupe, 302, Autolite 4100, C4, 3.00
Joe is offline
post #5 of 8 (permalink) Old 12-27-2012, 03:01 PM Thread Starter
its only there on highway speeds, not in braking at all.... i can even put it into netural and bring the engine to an idle and its there... its not bad enough to stress on it too much.. i just always saw those balance weights on the drums.. i know the privious owner had the hole drum system rebuilt a couple of years ago and she didnt drive the car but 2000 miles in those two years... i ruled out flexplate cuz the vibration isnt there when i hold rpm. its soooo hard to describe really.. its kind of like a pulsating vibration like you would get from a wheel, but the wheels are new, tires are new, all high grade stuff. i swap out wheels and tires to go from "drag" look to "road car" look. i have a totally seprate set of wheels for each look... just wondered if any drum brake users ever had this before... my last 68 came with the disk brake option so i never delt with drums before which is why they are going bye bye...lol.. well and the fact the car has almost 2 1/2 times the power over the little 289...
post #6 of 8 (permalink) Old 12-27-2012, 03:13 PM
If you can, swap your tires front to back and see if the vibration moves with the change. It's not out of the ordinary to have a tire with a shifted belt or that has too much runout but will balance otherwise. Also, there are places with on-the-car balancers that will end up balancing your wheel/tire/drum together.
19079 is offline
post #7 of 8 (permalink) Old 12-27-2012, 03:15 PM
Joe
If the vibration is there in neutral, then it cannot be from the brakes or wheels. It has to be coming from the engine or torque converter. Nothing else is moving. Or do you mean you can feel it when putting it in neutral while you are moving?
Joe is offline
post #8 of 8 (permalink) Old 12-27-2012, 10:28 PM Thread Starter
Yea my bad I ment when I'm at speed and put it into natural and bring it to idle costing 70 mph... I know it's not going to drive smooth as my 2012 Charger rt lol. I hope it gets smoother when the disk brakes are installed...
