65 V8 Oil Pan Replacement - Vintage Mustang Forums
post #1 of 9 (permalink) Old 01-02-2013, 12:22 AM Thread Starter
If I drop the cross member on my 65 V8, will I be able to get the oil pan off ?
flyind1 is offline
post #2 of 9 (permalink) Old 01-02-2013, 01:50 AM
LeeFred's Avatar
I did this recently. Once I removed the crossmember, I was able to remove the oil pan. It's a tight fit, but can be done. Basically, drop the crossmember, and then remove all the bolts from the oil pan. Pull the front of the oil pan down, and remove the two bolts that hold the oil pump onto the engine block. You can get in there with a 9/16" wrench. Lower the oil pump into the pan, and then slide the oil pan forward until you clear the center drag link.
Another way would be to remove the crossmember and also the center drag link. Then you can lower the oil pan straight down without removing the oil pump.
Of course, I am assuming you're talking about a stock oil pan...
LeeFred is offline
post #3 of 9 (permalink) Old 01-02-2013, 06:32 AM
22GT's Avatar
I have done this by removing the crossmember, and detaching the idler arm from the frame.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #4 of 9 (permalink) Old 01-02-2013, 08:26 AM
Z65
Z65's Avatar
Same here - just did this recently and didn't need to disconnect the oil pump at all. As 22GT says, drop the crossmember and detach the idler arm. Not too hard at all actually.
Z65
5F07A, 3-spd, A-code hardtop - Honey Gold w/ black roof - on order sheet & painted by dealer prior to delivery
Ordered by my parents in September 1964, Built in October, Delivered in November...
left = Summer 1965 w/ me in photo, right = current
Z65 is offline
post #5 of 9 (permalink) Old 01-02-2013, 02:28 PM
LeeFred's Avatar
Doh.....I never even thought of dropping the idler arm. Sometimes the most obvious thing is hidden from view. Filed away for future reference!
LeeFred is offline
post #6 of 9 (permalink) Old 01-03-2013, 12:02 PM
Yup, crossmember and lowered the drag link idler. Weaseld it out pretty easy. Only took about an hour to swap in a new pan. Very pleasant. Now try to do one on a foxbody.
88cougargt is offline
post #7 of 9 (permalink) Old 01-04-2013, 08:47 PM
Shop manual has detailed instructions....................
Leon Narozny is offline
post #8 of 9 (permalink) Old 01-04-2013, 09:25 PM
I won a special award
Maxum96's Avatar
That's how I've always done it in a Mustang.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11.5:1 compression, Victor Jr. intake, solid roller cam with shaft mount roller rockers
Tremec TKO 5 Speed
Maxum96 is offline
post #9 of 9 (permalink) Old 01-04-2013, 10:25 PM
Black Gold 380R's Avatar
As everyone has said, drop the cross member and the drag link and you will not have any problems. I just did this as well and I have long tube headers and it still came out.
1965 Coupe
2003 Cobra Coupe
2003 Cobra Convertible
2003 Roush 380R
Black Gold 380R is offline
