Should an engine have oil in it even if it's not going to be run for a long time? - Vintage Mustang Forums
Old 01-02-2013, 06:44 AM   #1 (permalink)
mjb1032's Avatar
Default Should an engine have oil in it even if it's not going to be run for a long time?
I put the 'done' engine back into the car a few months ago and am curious of this....
I used assembly lube when I put it all together, on the crank, cam, lifters, pushrods and rocker arms. I also wiped oil on the cylinder walls.
This engine won't be started for a long time as I'm working on other things.
Body/dash/wiring/ carb needs rebuilding,etc..
Is there any reason to add oil now?
I know I could spin the oil pump through the removed distributor hole, and get oil up to the valvetrain; but is this necessary?
Would the oil breakdown in any way just sitting in the pan?
I assume it's best to leave the antifreeze out too.
Any thoughts?....
Marc
Happy New Years all
Edit: The car is in an unheated garage that's attached to the house.
The temperatures fluctuate somewhat, but it doesn't get too cold in there.
Slowly restoring and improving dads '68 289 Coupe...
mjb1032 is offline   Reply With Quote
Old 01-02-2013, 07:49 AM   #2 (permalink)
With the assembly lube applied properly all over the rotating parts it is going to be just fine.
No worries. Just keep the valve covers on, the carb hole and exhaust ports covered and you shouldn't have any worries.
1970 Mustang coupe.
347 with world products heads, roller cam, roller rockers, Cal custom finned valve covers, performer RPM intake and a holley carb.
Hooker headers, jegs 2.5 exhaust.
C4 trans with a shift kit and PAW converter
http://s4.photobucket.com/albums/y12.../70%20mustang/
Has jegs drag star knock offs now..... More to come when i get home!
1970_347 is offline   Reply With Quote
Old 01-02-2013, 05:05 PM   #3 (permalink)
1970s right. Should be OK.
It's very cheap to buy a priming rod that sticks in your drill and turns your oil pump.
I always prime my engines if they have been sitting for a long time or the first start-up after a build. Also identifies any leaks before they are coating the engine bay with rust preventative.
88cougargt is offline   Reply With Quote
Old 01-02-2013, 05:16 PM   #4 (permalink)
+1 on 1970_347 and I would place it a large plastic bag.
sanch052 is offline   Reply With Quote
Old 01-02-2013, 07:04 PM   #5 (permalink)
mjb1032's Avatar
Thanks guys
Old 01-02-2013, 09:48 PM   #6 (permalink)
bartl's Avatar
+1 on making sure ALL the holes are plugged PLUS I'd put it in a plastic bag with some desiccant pouches or tubs.....
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
Old 01-02-2013, 11:14 PM   #7 (permalink)
summit sells plastic engine bags that are pretty durable and cheap. its what i use.
oil in the pan or not doesnt matter, because its just sitting in the pan.
Lee12609 is offline   Reply With Quote
Old 01-03-2013, 12:14 AM   #8 (permalink)
Just cover the holes that things can/will fall into (Trust me on that one). Other than that, no reason to at all! Do you put everything else you own into a bucket of motor oil when it's sitting in your garage? It's just sitting in the oil pan and you'll want to change it later anyways (not necessary, but you will want to).
JohnnyK is offline   Reply With Quote
Old 01-03-2013, 01:59 AM   #9 (permalink)
Default Oil Pressure
Any thoughts?....
Marc
Happy New Years all
ajb4227 is offline   Reply With Quote
Old 01-03-2013, 04:53 AM   #10 (permalink)
Titus_RacerX's Avatar
Where can I get a "priming rod" for my 289? The car has been sitting for 10+ years and I'm sure it's pretty dry.
Titus_RacerX is offline   Reply With Quote
Old 01-03-2013, 05:25 AM   #11 (permalink)
Fast68's Avatar
I don't know where to tell you to get a priming rod, however putting some oil in the cylinders with an eye dropper through the spark plug holes will protect from scoring the cylinder walls when you start it from sitting for so long. Probably a week in advance wouldn't be such a bad idea. A couple tablespoons in each cylinder. Expect whoever is in the direction of the wind to get asphyxiated when you first start it...
*fuel line could be loaded with crud along with gas tank as you probably know.
" Am I hallucinating here? Just what in the hell do you think you're doing? "
Fast68 is offline   Reply With Quote
Old 01-03-2013, 06:57 AM   #12 (permalink)
If you have an old distributor you can make one from that.
Or buy two of these and weld them together. This is from National parts depot.
6A618-3
Add To Wish List
DRIVESHAFT OIL PUMP STANDARD REPLACEMENT
DRIVESHAFT, OIL PUMP, STANDARD REPLACEMENT
Price: $9.05 EACH
YearModelFits Information
1969 - 1973MUSTANG351W
1978 - 1996BRONCO351W
1980 - 1996F100-350351W
Nitro Blue is offline   Reply With Quote
Old 01-03-2013, 10:06 AM   #13 (permalink)
Get a 1/4", 6 point, deep socket with 1/4" drive and a 12" long 1/4" extension. Chuck the female end of the extension in a drill, put the socket on the male end, remove the distributor and spin the oil pump drive shaft with your new "priming rod".
awhtx is offline   Reply With Quote
Old 01-03-2013, 11:23 AM   #14 (permalink)
you forgot one step
Use some tape to attach the socket to the extension!
Dropping the socket into the oil pan is one of those.... "that didn't just happen did it?" moments.
