On a 351W motor is there suppose to be a gasket between the pump and the block? I know that there is one between the pump and the pick-up tube but nor sure on the other?
There was a debate about this on a 5.0 forum, and the answer seemed to be a coin-toss. On one hand, people said if a gasket is available, use it - but on the other, some said using a gasket increased the chances of sucking a piece of that gasket (with age) into the oil-pump.
Don't know on the 351w, but some of the engine builders said if the surfaces are completely flat (block and pump) they prefer NOT to use a gasket. Apparently if the surfaces are not perfectly flat, you can file them flat. FWIW - I've only assembled 4 or 5 SBFs, but I've never used a gasket there, and never had a issue.
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
I've torn down a number of engines I believe to have the original pumps and they had no gaskets. I always use one though.
I once had a 289 loosen up the pump to block bolts. Cruising at 2500 rpm all oil pressure would go away then return as I slowed. Since then I also use Loc-Tite on those bolts even though the factory didn't do that either. People who have quite a bit of money in a race engine will safety wire the oil pump and pickup bolts which is also an excellent non-factory practice.
Are we talking about the high pressure side or the low pressure?
What's a bolt on
Hmmm - you're right. Since this gasket is between the pump and block - that would be the output side going away from the pump. In the highly-unlikey event a "chunk" of gasket did break-off - it should head straight to the filter with no real chance of sinking back towards the pump... I still think it's a toss-up. All the factory SBFs I've torn-down did not have a gasket there...
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
