Need help with blinker lights - Vintage Mustang Forums
Old 01-04-2013, 07:14 PM   #1 (permalink)
Default Need help with blinker lights
I have a 1970 mustang. New painless wiring harness. When i put the blinker on both fronts are on also interior indicators. I redid front ground, new blinker switch and flashers.
Bryon is offline   Reply With Quote
Old 01-04-2013, 08:07 PM   #2 (permalink)
bartl's Avatar
Check and make sure the bulbs are in correctly. Take them out, one at a time and see if that fixes the problem. If so you'll know where to look.
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
Old 01-04-2013, 08:34 PM   #3 (permalink)
I pulled bulbs allready. I'm no electric wizard but up at blinker switch connection there is power to both fronts which i wouldnt think. I already replaced the china pos switch with one from Drake.
Old 01-04-2013, 09:50 PM   #4 (permalink)
bartl's Avatar
Must be contacts at the switch then as there are 4 separate "outs" to each of the lamps.
Old 01-05-2013, 08:01 AM   #5 (permalink)
Zudman's Avatar
Bryon Had the same problem with mine, I can't find my notes but I will give it a shot on memory. Painless wiring harness # 20122 for 69/70 has 3 wires for turn and park lights, disconnect the ground wire believe it's BLK/WHT. Reason being, 69 has a external ground, 70 internal ground the screws holding the housing to the bumper are the ground.I believe that's what I did, and it worked. Good luck don't know how many hrs I spent on that one. If my garage warms up today, I'll take a look at it...It' cold here in WI Zudman
Zudman is offline   Reply With Quote
Old 01-05-2013, 08:57 AM   #6 (permalink)
Thanks for help. I will try. Just turned on the heat. I live in Mosinee WI, cold here to
Old 01-05-2013, 09:20 AM   #7 (permalink)
Kenster's Avatar
Zudman, I see that this was your first post. Welcome to the board and thanks for jumping right in with some help based on your experience.
Do a "hello" thread and tell us about yourself and your car.
Cheers!
Kenster is offline   Reply With Quote
