65 Mustang Squeaking/Creaking Steering Wheel - Vintage Mustang Forums
Old 01-05-2013, 08:21 PM   #1 (permalink)
Default 65 Mustang Squeaking/Creaking Steering Wheel
My 65 Mustang steering wheel squeaks/creaks when you turn it in any direction. Could this be a bearing that has worn out? Is it this bearing that needs to be replaced? Is it this bearing?
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
Or do I need to lube the steering box? It sounds like it is coming directly from the steering wheel.
Any help would be appreciated.
Chris31419 is offline   Reply With Quote
Old 01-05-2013, 08:46 PM   #2 (permalink)
22GT's Avatar
You could try lubricating the slip rings. If that doesn't work, pull the wheel and lubricate the upper shaft bearing. If you examine the bearing and find it's shot, it can be replaced inexpensively.
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 01-05-2013, 09:10 PM   #3 (permalink)
I tried looking at this diagram but don't see a slip ring? Can someone point it out to me on here?
Also, to lubricate the slip ring, do I have to remove the steering wheel?
Mustang Steering Columns Mustang Steering Column Solid Shaft Photo 2
Old 01-05-2013, 09:19 PM   #4 (permalink)
22GT's Avatar
The slip rings are on the back of the steering wheel, and a quick shot of silicone through the gap between the wheel and column will tell.
Old 01-08-2013, 12:16 AM   #5 (permalink)
I just wanted to say thanks for the help. I sprayed white lithium grease on the slip ring and the noise went away.
Old 01-08-2013, 12:43 AM   #6 (permalink)
HyePo66's Avatar
luv that stuff
1966 Mustang GT RestoMod Project: 307c.i.d.,Holly 600 4brrl, TrickFlow Heads, Power Disc Brakes, Integral Power & Tilt Steering, AOD, 9" 3.50 posi rear end & a bunch of other stuff.
Project start date 1999. Completion date... fagidaboudit!
First Mustang, 1966 I-6 w/Pony interior (bought in 1980 for $600.00 - sold in 1984 for $600.00)
http://www.myrestomodmustang.com
Like the MyRestoMod project on Facebook:
http://www.facebook.com/pages/1966-M...88268267888907
HyePo66 is offline   Reply With Quote
