Rotissiere help - Vintage Mustang Forums
Old 01-07-2013, 10:03 PM   #1 (permalink)
Israel's Avatar
Default Rotissiere help
Need some help from you firsthand rotissiere guys.
Where/how did you attach it to the front/back of car.
How tall from the ground is the "pivot point", by this I mean the centerline of the round tube that you rotate to spin the shell.
After you built yours, what would you have, or did you change to make it better?
THANKS!
Wife,........."You drove how far for that thing?"
Friend,......."Dude, thats a rusted piece of sheet."
Israel is offline   Reply With Quote
Old 01-07-2013, 10:14 PM   #2 (permalink)
Greg'66 5.0's Avatar
I attached the front to the bumper bracket mount holes on the outsides of the front frame rails. At the rear, I attached to the rear bumper mounting holes in the taillight panel. Another common rear attachment point is to use the leaf spring holes or the exhaust hanger holes in the rear frame rail. My rotating points were about 6" below the fuel filler and just slightly above the radiator crossmember and that seemed to hit the center of gravity pretty good.
My pivot point was probably around 42-48" from the ground, which put the doors about a foot off the ground when I rotated the body 90 degrees. To make sure you won't hit the body against the ground, measure the body at its widest point, divide by 2, and add at least a foot to that and that's a good place to start for a pivot point - keep in mind that this point needs to be measured above any rotisserie structure (i.e. square tubing) that connects the front to the rear.
My rotisserie contraption was the only one I have seen that was made from pressure treated lumber instead of steel. It was fairly inexpensive and worked great. In an ideal world, I would have had one made from steel with long ram hydraulic jacks front & rear to allow the height to be changed. A powered rotating assembly would be nice, but isn't necessary if your rotating axis goes through the body's center of gravity. I would have also liked to have the ability to lock the body at various points in the rotation, but I managed just fine without. I used ratchet straps or slid a piece of wood under the body against the bottom of the frame rails to keep the body from turning.
'66 Emberglo Coupe - Restoration in progress
Modifications:
5.0 EFI conversion
T56 6-speed
Rod & Custom Motorsports IFS
TCP subframe connectors
Vintage Air Heat & AC
'99 Black Cobra - Daily driver
Greg'66 5.0 is offline   Reply With Quote
Old 01-07-2013, 10:30 PM   #3 (permalink)
Israel's Avatar
Got any pics of it, kinda want to have a pic to go with your description
Not very imaginative
Old 01-07-2013, 11:25 PM   #4 (permalink)
This was my home made rotisserie. I had to make it where it could roll over in my low ceiling with a door opener above it. It cleared the opener and the bottom rail by a couple inches.
You can see my front mount, but the rear was just a straight bar that bolted to the rear bumper bracket holes.
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
ScottsGT is offline   Reply With Quote
Old 01-07-2013, 11:52 PM   #5 (permalink)
Israel's Avatar
The rear rotissiere attachment just bolted into the rear bumper holes.
Next, after attaching the front rotissiere to the front frame rails, you add height to the vertical section in the front until the front/back pivot points are the same, correct?
At this point the shell is balanced, but not yet tall enough to actually spin, until you raise easch side the same amount to clear the rotissiere?
I understand that the pivot point front and rear is actually determined and adjusted before anything is mounted, but I just wanna be sure that I fully understand the basic logic of finding the center of gravity for free spinning.
Old 01-08-2013, 05:57 AM   #6 (permalink)
rdlagray's Avatar
It would help to know what type rotisseri you have. Raising the car to the pivot point does not balance the car. That is done by adjusting the bracket attachment that slides in the main base. After adjusting the bracket it may be necessary to readjust the main pivot point
Randy
65 coupe GT C4 black/red pony restoring
65 fastback A code C4 AC silver blue Driver
rdlagray is offline   Reply With Quote
Old 01-08-2013, 06:04 AM   #7 (permalink)
rdlagray's Avatar
I don't remember what my pivot point ht was but after I tied the two ends together with tubing I had to raise my pivot point. My pivot points on both ends are the same but the adjustment on the brackets are different from end to end. Notice the square tubing through the head on the rear is sticking through farther than the on on the front. This is where the balancing is done.
Randy
Old 01-08-2013, 06:31 AM   #8 (permalink)
sheeesh Isreal jsut buy my Rost .... LOL
hughnews1 is offline   Reply With Quote
Old 01-08-2013, 06:47 AM   #9 (permalink)
Another Fastback's Avatar
Has anybody ever tried making one out of 3" black/galvanized pipe ?,one of my freinds owns a plumbing company and said just give him the size of pipe and lengths and he can get it for me,after I am done with it they would just reuse it since they cut and rethread it any way,if so what pipe woukd be used,thanks,Pete
Another Fastback is offline   Reply With Quote
Old 01-08-2013, 07:57 AM   #10 (permalink)
When I was done with rotating the body, I took it off the rotisserie and set it down on the base so I could easily move the car any direction:
Modifications:
5.0 EFI conversion
T56 6-speed
Old 01-08-2013, 09:04 AM   #11 (permalink)
Greg that is really cool. Very resourceful!
65fstbpieces is offline   Reply With Quote
Old 01-08-2013, 09:10 AM   #12 (permalink)
Israel's Avatar
Making one similar to Scott GT's two engine stands
Old 01-08-2013, 09:10 AM   #13 (permalink)
Israel's Avatar
Had I only known,....
Besides I'm already buying enough of your rusted, almost 50 year old, beat up, second hand, used crapola!
Old 01-08-2013, 09:19 AM   #14 (permalink)
If you PM me your email addy, i'll send you a couple plans i found around this here parts.
Restoring a 65 Mustang i've owned since i was 14...don't ask how old i am now.
Rudder! is offline   Reply With Quote
Old 01-08-2013, 11:28 AM   #15 (permalink)
Israel's Avatar
So after attaching either the front or the back, the other end just needs to be adjusted up or down to find the sweet spot,...
Can you put a level on the roof and adjust from that?
