1969 coupe, car is on jack stands, spring is out. Old UCA is bolted to shock tower. Need to seperate upper ball joint from spindle. Cotter pin is out, castle nut backed off. Made up the homemade ball joint press as shown on Daze website. Do I need to support LCA before using the press? I am not replacing the LCA, just the UCA at this time. Don't want to risk mushrooming studs with this tool. How much pressure should it take for the UCA ball joint to release? Any other tips? Thanks.
Don't need the spring in place. Daze BJ tool presses between upper and
lower BJ studs, I'm assuming? (Like the tool pictured)
If so, clamp it in place with some tension and whack the fat part of the spindle
exactly where the BJ stud is at. BJ nut does not have to be off, just loosened.
Tension from the tool wouldn't be enough about 85% of the time. You need
a well placed hammer-strike. Wear goggles.
- Douglas Adams
For convenience only.... a milk crate is adequate. There's a few pounds
but not much weight involved. If the strut rods are in place, the LCAs
really won't go too far.
- Douglas Adams
Spin off the castle nut and then thread it on upside down until it's even with the end of the stud. Tighten up your tool and then tap the spindle where the stud goes through with a hammer. Tighten tool 1/4 turn and tap again. Repeat until it pops.
Yes, I would support the LCA and spindle with a floor jack or jack stand that keeps a bit of the weight off.
I know the spring isn't in there but I usually don't recommend taking nuts all the
way off of ball joints. Particularly for a novice.
Getting too comfortable with suspension work is how a close friend of mine
ended up unconscious in the bay of a Ford dealer's shop and missing 5-6 teeth.
At the time he was one of 3 corporate Ford Parts & Service troubleshooters.
(those are the guys that go in there and fix warranty issues that the dealer
line mechanics couldn't)
- Douglas Adams
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
