69-70 PS return hose - Vintage Mustang Forums
Old 01-17-2013, 01:42 PM   #1 (permalink)
Blues Power's Avatar
Default 69-70 PS return hose
anyone know why the ret hose from the PS pump is 2 peices
right near the chassis insulater is a junction fitting ( dont know what else to call it) with clamps.
The shop manual shows it as well.
. I replaced it with a one piece line and I guess it was put there prob there for servicing reasons. anyone know what the reason is to have it 2 pieces as opposed to 1 and having 1 less fitting to worry about.
1970 Mach 1 San Jose built Dec 23 1969. Marti says 1 of 7. Purchased in 1987. Original family owner of the powertrain 351C 2v FMX.
1993 GT 11,000 miles, Built 2-12-93 Auto, 3:27 Axle, cloth, sunroof. Untouched except for rubber and battery, Purchased new 8-3-93. still has the factory windshield fluid and new car smell.
Blues Power is offline   Reply With Quote
Old 01-17-2013, 02:05 PM   #2 (permalink)
I couldn't tell you but I replaced the return line yesterday because my new repro pump makes the line short. Last year I changed out the one with the fitting. I know that hose releases the fluid when turning. Why?? Look at my last thread I Made today. Haha
Dave
2004 Nissan Titan Crew Cab
1966 Ford Mustang Original 289
Edelbrock RPM Performer Heads; bored .30 over
Weiand Stealth Intake, Holley 600 CFM Carb.
Comp Cam 268H 9.5:1 Speed Pro Pistons
Patriot Tri-Y Headers w/ 2.5" H Pipe, Flowmaster 40S
620 1" drop in front, CSRP Front Disk Brakes.
Ford 8 3.40 trac-loc rear end
GO RAIDERS!
sdmustangrider is offline   Reply With Quote
Old 01-17-2013, 08:51 PM   #3 (permalink)
dalorzof's Avatar
Just a guess, but maybe the hoses were on the pump and on the ram pre-assembly to make the line keep moving... they install the two, then connect the hoses at the bracket, not fish up under the car to try to get it on the pump outlet or ram, which are both not the easiest access....
A press fit and clamp is way faster than accessing/torqueing fittings...
"True terror is to wake up one morning and discover that your high school class is running the country."
Kurt Vonnegut
8R03S : 76A I 2A 15M 72 5 U
8R01S : 65A B 2A 28M 72 7 5 - Factory GT
8R01C : 65A M 2A 01E 72 2 W - CS/GT
8F01X : 65A I 2G 20E 24 1 U - EXP500 to-be
dalorzof is offline   Reply With Quote
