She's welded in there I believe. Welded strangely as well (folded over and welded, then coated with sealer, if I remember?) Scrape off the sealer from around the perimeter and you should be able to see what I mean.
I was just talking to a guy about this...what do you plan to do with that area?
I was telling him about the quarter window mod wherein you install glass from a SN197, but the only ones I had seen had trim around the widow, not the floating gas of the newer cars...he thought we might be able just to cut it out of a wrecked one and weld the whole piece into mine...that sounded a little adventurous for my taste, but it may work.
1968 Fastback: 331 stroker, FTI cam, N351 Heads with a few upgrades, 4r70w w/3600 stall, 9" locker w/3.70 gears
The real challenge i found when looking into putting windows in place of the "grills" on the 68 was what to do with the interior? A custom fiberglass or plastic assembly would have to be made, and everything i came p with in concept would have looked out of place, IMO.
1968 C Code Coupe - Getting a 289 and AOD - ON HOLD
1968 C Code Fastback - Getting a 351W and Tremec TKO 5 Speed - WORK IN PROGRESS!
It is spot welded. A new full quarter panel from Dynacorn will include this part in the panel. The panel will need to be replaced if using the Dynacorn quarter. I just pulled these parts off a 67 about 2 months ago.
I like to use a 1/8" drill bit to make a pilot hole for a spot weld removing bit. Napa has a good one with a replaceable bit. I also dip the bit in a small cup of oil between holes. It helps the bit last a lot longer.
Take a propane torch and a wire brush to that area and burn off all the seam sealer and you can see the spot welds that must be drilled out.
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
