tips to loosen door strike posts needed - Vintage Mustang Forums
Old 01-20-2013, 06:28 PM   #1 (permalink)
Default tips to loosen door strike posts needed
HI VMF Team!
I need to adjust the door strike posts that the door latch grabs onto that is bolted to the body with 2 huge philip style screws. I can't get them to budge. Does anybody got any magic tips to break them loose. I am afraid that I could strip out the head if I am not careful.
Bob Taylor is offline   Reply With Quote
Old 01-20-2013, 06:30 PM   #2 (permalink)
carlite65's Avatar
i have used a hand impact driver for just that task.
carlite65 is offline   Reply With Quote
Old 01-20-2013, 06:34 PM   #3 (permalink)
not sure what you mean by a hand impact driver, that is not the same as an impact wrench?
Old 01-20-2013, 06:36 PM   #4 (permalink)
Try Sears or one of the local auto parts stores for an impact screwdriver. Harbor Freight has them for under $10.
SunnDogg is offline   Reply With Quote
Old 01-20-2013, 06:37 PM   #5 (permalink)
finbar's Avatar
It's the one you hit with a hammer.
1966 289 A code GT coupe C4
finbar is online now   Reply With Quote
Old 01-20-2013, 06:49 PM   #6 (permalink)
so you wack the end of the tool with a hammer? I will have to head over to Harbor Freight.
Old 01-20-2013, 07:35 PM   #7 (permalink)
Caper50's Avatar
Just did mine, you'll definitely need the impact. They usually have an arrow indicating left or right, remember righty tighty, lefty loosey...couldn't resist.
Brian
66 Mustang Coupe 289-2V under construction
Caper50 is offline   Reply With Quote
Old 01-20-2013, 07:53 PM   #8 (permalink)
Also whamy bamy!
slim is offline   Reply With Quote
Old 01-20-2013, 08:12 PM   #9 (permalink)
bryancobb's Avatar
You really need a friend to hold a chunk of steel or body-dolly behind it as you whack the impact driver. The jamb is pretty thin sheet metal and that whacking makes a LOT of force.
bryancobb is offline   Reply With Quote
Old 01-20-2013, 08:28 PM   #10 (permalink)
finbar's Avatar
A dry run on a lesser part would give you a feel of how the tool works.
The heads may be pozidriv, using a phillips driver will cam out and damage the head.
Old 01-20-2013, 09:17 PM   #11 (permalink)
Maxum96's Avatar
I have the Craftsman one. Nice piece and not expensive at $24.99
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11.5:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96
Maxum96 is offline   Reply With Quote
Old 01-20-2013, 10:49 PM   #12 (permalink)
Agree with others. You NEED an impact driver, works great.
Craftsman Impact Driver - Tools - Mechanics & Auto Tools - Automotive Specialty Tools
1968 C Code Coupe - Getting a 289 and AOD - ON HOLD
1968 C Code Fastback - Getting a 351W and Tremec TKO 5 Speed - WORK IN PROGRESS!
thespazardman is offline   Reply With Quote
Old 01-20-2013, 10:50 PM   #13 (permalink)
Even a large Phillips screwdriver and a hammer will do the trick sometimes. Put twisting force on the screw and start tapping firmly on the back of the handle. Sometimes just the shock will break it loose.
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
ScottsGT is offline   Reply With Quote
Old 01-20-2013, 11:43 PM   #14 (permalink)
Good to know this was going to be one of my next mini projects. Does anyone have a link to the harbor freight impact driver? I searched but couldn't find one. You guys think an 18v impact gun would work?
2000 Mustang Gt (Daily Driver)
1969 Mustang Fastback (Project)
WiseBeyondYears is offline   Reply With Quote
Old 01-21-2013, 12:31 AM   #15 (permalink)
bartl's Avatar
I have impact bits in 1/2" drive that I put on my cordless impact wrench. Works great and no busted thumbnails.
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
