Fuel Pressure Regulator Location - Vintage Mustang Forums
Old 01-24-2013, 11:21 PM   #1 (permalink)
Default Fuel Pressure Regulator Location
Just bought a Holley fuel pressure regulator and I don't want to mount it on the side anywhere. This thing weighs next to nothing so I was thinking about getting creative with some AN fittings and running it inline with a filter before and after. What do you all think? I might be able to tuck it behind the distributor so it's not as noticeable.
- BluePrint Engines 347 Stroker, 400 HP, 421 lb. ft torque (On the Dyno & Installed)
- 4 speed Toploader
- Auto Meter gauges in the stock bezel
- American Autowire Installation (VMF & CJPP)
66FSTBCK is offline   Reply With Quote
Old 01-24-2013, 11:29 PM   #2 (permalink)
Show it off, keep it away from any sparks
Shady is offline   Reply With Quote
Old 01-25-2013, 07:17 AM   #3 (permalink)
buckeyedemon's Avatar
i added a bypass regulator and mounted it behind the carb to try and hide it.
Dearborn, March 31, 1969
buckeyedemon is offline   Reply With Quote
Old 01-25-2013, 08:20 AM   #4 (permalink)
I guess my main question is, is it ok to just suspend it inline with no actual mount? Just like the filter. The AN fittings and steel braided hoses are rigid enough to give it support IMO.
- 4 speed Toploader
Old 01-25-2013, 08:51 AM   #5 (permalink)
I put mine under the a/c and attached to the cylinder head.
Z.
'65 HiPo fastback
zray is offline   Reply With Quote
Old 01-25-2013, 10:26 AM   #6 (permalink)
Boom's Avatar
You shouldn't have any issues with it jsut supported by the lines. There are plates you can buy to mount it behind the carb I believe.
-Brett
1968 Mustang coupe 302
Getting ready for a 5.0 roller swap
Boom is offline   Reply With Quote
Old 01-25-2013, 10:40 AM   #7 (permalink)
it may be overkill, but I wouldn't put any more weight on the fuel lines, braided steel or not, that they have to carry. There are too many mounting choices to just let it all hang loose. The vibration of the engine compartment is going to put too much stress on unsupported components. Just my opinion
Z.
'65 HiPo fastback
Old 01-25-2013, 10:50 AM   #8 (permalink)
It's pretty common for racers to have it suspended. Some say it's better since it helps it not receive any shocks or jolts from engine vibrations/chassis.
I had my mounted on my engine for about a day. I didn't like how warm/hot it got. Try to keep it cool as possible! Suspending the regulator helps with this also.
Chaz
'71 Fastback
9in 31 spline 3.50 Winters Performance True Trac, 4r70w manual valve body and hardened gear set, 408w roller with ~11.2 Canfields, MME cam, Aluminum MMC driveshaft, 3" Exhaust.
CrackrStang71 is offline   Reply With Quote
Old 01-25-2013, 12:19 PM   #9 (permalink)
I'm going to use one of these for my Aeromotive FI regulator.
http://www.summitracing.com/parts/sum-210250/overview/
1995 GT convertible - Laser Red
1995 GT convertible - Black (Son's ride)
1966 GT Fastback under restoration- Code T Red
with White LeMans stripes.
ScottsGT is offline   Reply With Quote
Old 01-25-2013, 12:30 PM   #10 (permalink)
I thought about that but I already bought a dual feed line with AN fittings so that won't work. However, this one would work, but it only comes in blue and red. Would have to paint it black or something.
http://www.summitracing.com/parts/aed-6092/overview/
- 4 speed Toploader
Old 01-25-2013, 01:52 PM   #11 (permalink)
frdnut's Avatar
There is a bracket that uses the two side carb studs to support it available from summit.
Oops I see it is the one that ScottsGt posted the link to.
68 J code sprint, 408W with vic jr top end, Pro Systems 950HP Holley carb,Camshaft Innovations custom solid roller ,Hooker 6208s,Toploader,4:11 Detroit locker...
11.82@ 120.85mph
frdnut is offline   Reply With Quote
Old 01-25-2013, 02:36 PM   #12 (permalink)
Originally Posted by CrackrStang71 View Post
It's pretty common for racers to have it suspended. Some say it's better since it helps it not receive any shocks or jolts from engine ......."
Chaz
What is fine on a race car is often unworkable on a street car. Race cars enjoy complete tear downs on regular intervals. Street cars seldom have that much attention.
Z
'65 HiPo fastback
Old 01-25-2013, 03:02 PM   #13 (permalink)
Z
Okay then. I do it on my street car :-) I definitely wouldn't have mine mounted on my engine again. Have you not noticed how hot your gets? I've had it hang and I've had it mounted on fender apron.
Many people do it on their street cars. Do as you please.
Chaz
'71 Fastback
Old 01-25-2013, 03:58 PM   #14 (permalink)
Mine stays cool to the touch. My radiator fan blows over that area pretty good. It's not a clutch type, those little HiPo fans move a lot of air
'65 HiPo fastback
Old 01-26-2013, 12:33 AM   #15 (permalink)
Maxum96's Avatar
I have mine mounted on the left side front fender apron. You can just see the top of it in this picture. I have a custom 1/2" fuel system in my car from the fuel cell. I have all braided steel fuel lines under the hood.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11.5:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96
Maxum96 is offline   Reply With Quote
