Correct. The shaft is retained to the end of the axle housing with 4 bolts. They are accessed through a hole in the axle flange. No need to remove the brakes. The hardest part is pulling the axle after the 4 bolts are out. Some come out easy, some require "encouragement." One easy encouragement method is to use the brake drum reversed as a junior slide hammer.
Good luck,
MrFreeze
"Life is what happens to you while you're busy making other plans."
'66 GT Fastback show car, nightmist blue, warmed up original 289 & T-5Z, 3.80 trac-loc, AC, PS, pony interior, Retrosound, rally pac
'66 Coupe driver, Bullitt green, 302HO w/ 351W heads, roller rockers, Holley 600, T-5Z, 3.55 trac-loc, collapsible column, tank armor, disk brakes, shoulder belts
'11 BMW 335i X-drive, 6 speed manual, all the bells and whistles
