Motor question / tranny question - Vintage Mustang Forums
Old 01-30-2013, 07:30 PM   #1 (permalink)
Mustang Nate's Avatar
Default Motor question / tranny question
Hey guys will a 351w and c6 tranny fit in a 1966 mustang coupe without any fab work??
Mustang Nate is offline   Reply With Quote
Old 01-30-2013, 07:32 PM   #2 (permalink)
Harleydave's Avatar
351w is a tight fit in a 66. I'll let someone who has one chime in.
68 Fastback. 351W/Toploader
Harleydave is offline   Reply With Quote
Old 01-30-2013, 07:36 PM   #3 (permalink)
Bucket Lister's Avatar
Both will be tight. The 351W is doable, but you will have to do some shock tower modification. You may need a bubble hood too. The C6 will be even tighter. You will have to modify the trans tunnel. MustangSteve has a tutorial about doing this Google MustangSteve.
Bucket Lister is offline   Reply With Quote
Old 01-30-2013, 07:42 PM   #4 (permalink)
Ok thanks guys ill stick to building a 302
Old 01-30-2013, 07:59 PM   #5 (permalink)
cmefly's Avatar
The 351W fits with no problems. You do need the correct headers like Hooker Supercomp 6208. Hood clearence can be an issue with some intakes. I would not use a c-6 as the c-4 fits better and uses less power and can be built to take a lot of abuse. If going the 302 route I would do a Stroker 347.
cmefly is offline   Reply With Quote
Old 01-30-2013, 11:22 PM   #6 (permalink)
bartl's Avatar
Just do a 351W and a C4...plenty strong enough.
http://forums.vintage-mustang.com/signaturepics/sigpic19079_1.gif
6F09A 63A 8 26 09D 71 1 5
bartl is offline   Reply With Quote
Old 01-31-2013, 06:49 AM   #7 (permalink)
22GT's Avatar
Yes. You will need to be a bit creative with the trans crossmember.
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 01-31-2013, 06:57 AM   #8 (permalink)
supershifter2's Avatar
use the hooker engine swp headers. trade the c6 for a c4. the c6 eats up 55 hp compared to the 25 a c4 eats up. the c4 will easily handle the 351w. i put a 351w in a 65 with the hooker engine swap headers and didnt modify anything.
supershifter2™ < !
supershifter2 is offline   Reply With Quote
Old 01-31-2013, 09:04 AM   #9 (permalink)
ran a 351w and c4 in a 66 convrt for 7 years and over 100k using stock 289 exhaust manifolds but the drivers side is tight against the steering box but a couple of washers under l/h mtr mt gives a little clearance. only had to change out l/h ex manifold 1 time. wes
mustang656man is offline   Reply With Quote
