Anyone's sporting the led light bulbs? - Page 2 - Vintage Mustang Forums
Old 02-09-2013, 09:04 PM   #16 (permalink)
turbowars's Avatar
No I didn't see a video. Where at?
Found it!:-)
turbowars is offline   Reply With Quote
Old 02-09-2013, 09:25 PM   #17 (permalink)
turbowars's Avatar
Just viewed the video and thats awesome. Im sold! Now to buy my car.
One question why cant you just leave the dash indicator lights alone?
Old 02-09-2013, 09:36 PM   #18 (permalink)
LED bulbs for the brake lights are definitely the way to go! Very bright and less electrical drag.
67 390 GTA Fastback
68 GT500 Shelby Convertible Replica
68 J-Code GT/CS
68 X-Code GT/CS
xcodegtcs is offline   Reply With Quote
Old 02-09-2013, 09:49 PM   #19 (permalink)
turbowars's Avatar
Strange that they dont make signal lights for a 67 or 69.
Old 02-09-2013, 11:54 PM   #20 (permalink)
Mustang Project - Product Display. 69 mustang
Dave
2004 Nissan Titan Crew Cab
1966 Ford Mustang Original 289
Edelbrock RPM Performer Heads; bored .30 over
Weiand Stealth Intake, Holley 600 CFM Carb.
Comp Cam 268H 9.5:1 Speed Pro Pistons
Patriot Tri-Y Headers w/ 2.5" H Pipe, Flowmaster 40S
620 1" drop in front, CSRP Front Disk Brakes.
Ford 8 3.40 trac-loc rear end
GO RAIDERS!
sdmustangrider is offline   Reply With Quote
Old 02-10-2013, 12:10 AM   #21 (permalink)
Well I know there are a lot of older folks on here and might not like the euro style but I have 5k HID headlights and they are AWESOME! Much better than stock and easy install too.
Before:
After:
1966 Coupe, 302 T-5 Azure Blue
66_5.0 is offline   Reply With Quote
Old 02-10-2013, 03:39 AM   #22 (permalink)
supershifter2's Avatar
Originally Posted by Kelly_H View Post
Not sure what you mean by full LED replacement assemblies turbowars, but here's mine:
As you can see, mine is the LED panel type. The kit I used splices into the stock harness and has a switch to turn them from sequential to standard blink cycles if desired. The LED panel was glued into place with silicone, wires were run through and taped, and the control panel for the lights was velcro'd up on the bracket that holds the trunk hinge. Took me a couple of hours including set time for the silicone and I really like them. The last picture shows how bright they are - if they're that bright in full light, imagine how bright they are at night They don't look euro at all I don't think?
Edited because I realized that the original poster was not turbowars and he was asking about the single bulbs - general consensus is that they're very good, I believe. I like my panels because they don't tend to diffuse out the light (i.e. they're not brighter in the center where the bulb is and more dim around the edges). Didn't run me much cash either. Sorry to be totally off topic!
where can I get those LED lights ?
supershifter2™ < !
supershifter2 is offline   Reply With Quote
Old 02-10-2013, 07:30 AM   #23 (permalink)
turbowars's Avatar
Sweet. Where do they sell those? Are they plug and play?
Before:
After:
Old 02-10-2013, 07:43 AM   #24 (permalink)
@Kelly_H - in the last picture where it shows the tail light illuminated, only 2 of the 3 bars of the tail light are lit up. By any chance was the picture taken while the lights were in "sequential" mode? I'd like to see a pic of those at night
LeeFred is offline   Reply With Quote
Old 02-10-2013, 07:59 AM   #25 (permalink)
You guys won't regret the led sequentials. I have them on my car, the 90 bulb per side and they light up great. No need for the 180 bulbs but if you want to spend more money, go for it. I got my kit from mustang project.
Dave
GO RAIDERS!
Old 02-10-2013, 12:20 PM   #26 (permalink)
68Fastang's Avatar
Do the LED bulbs require a different flasher?
68Fastang is offline   Reply With Quote
Old 02-10-2013, 04:03 PM   #27 (permalink)
I bought the kit from a local import shop (Yes I said import). They carry a kit which has the new headlight housing made for the HIDs and is VERY simple to install.
I have some pictures here of the install, HIDs installed in the '66 - Northern California Ford Owners*
And here is where I bought them, give them a call and see what they say
1320 Performance | HID
Old 02-10-2013, 04:24 PM   #28 (permalink)
If I'm not mistaken, it comes with the kit. Here you go. Just found it
Dave
GO RAIDERS!
Old 03-01-2013, 12:46 AM   #29 (permalink)
I like the LED's. Much safer and look good too!
strnge1957 is offline   Reply With Quote
Old 03-01-2013, 03:56 AM   #30 (permalink)
tx65coupe's Avatar
I don't have any LED's in mine. I don't plan on switching to them either. I do have the incandescent 3 bulb sequential tail lights though. Thats an improvement. I have GE Nighthawk bulbs in the tail lights and parking lights.
If I was to switch, I would get the full panel for the tail lights and not just the bulb, like what Kelly has. This setup is a great idea.
Also, I don't care for anything Sylvania makes with the Silverstar name. Their other bulbs are fine though. It might be 40% whiter, but definitely not brighter. Its actually dimmer, since it has the blue coating on it.
That housing is most likely made for an H4 halogen bulb, and has incorrect optics for HID bulbs. If thats the case, it will create excessive glare to oncomming drivers.
I'll stick with headlight relays and either 6024 Xtravision or do an H4 halogen conversion with the 55w/65w clear bulbs. Thats the same as most newer capsule bulbs.
1997 Cobra Convertible (stock)
1965 Mustang
Late Model 302 and T5 and Versailles 9 Inch
Edelbrock Heads, Cam, Intake, and Carb
JBA Headers and Dynomax Ultraflo Mufflers
http://forums.vintage-mustang.com/me...-100-1108.html
http://www.youtube.com/watch?v=LXk_MVV7V0g
tx65coupe is offline   Reply With Quote
