Problems with replacement motor mounts? - Vintage Mustang Forums
Old 02-09-2013, 09:13 PM   #1 (permalink)
Default Problems with replacement motor mounts?
Anyone have any problems with replacement motor mounts? I replaced the drivers side because it was broken. The first replacement mount from npd was clearly warped where the mount sits on the frame causing the frame bolt holes to not line up. I went to napa and got a new mount and it went in like a charm. I decided to do the passenger side today. Went back to napa, got the part, took the old mount out and the holes don't line up for the long bolt on the frame side of the mount. It's like the engine isn't heavy enough to compress the mount enough for the holes to line up.
Am I doing something wrong? Or is the tooling on these parts just hit or miss? Btw I trimmed the excess rubber on the mount on the side that contacts the frame and that helped the holes to almost line up but still no dice. Also I inspected that surface to ensure it was flat and it appeared to be. Thoughts?
1968 289 Coupe "Sally"
2002 GT Vert "Sasha"
VANILLA_GORILLA is offline   Reply With Quote
Old 02-09-2013, 09:44 PM   #2 (permalink)
kd4pwh's Avatar
I went through an ordeal too. I think my issue was with the odd ball 67 mount issue. I ended up having to modify the frame for the mounts to work.
But to answer your question, yes I went through I don't know how many anchor mounts before I found two decent ones. They're junk.
http://www.mustangbarn.com/PDFs/1964...r%20Mounts.pdf
More info in the link above
Chris
66 Coupe long gone
67 Coupe
Mustang on Flickr
kd4pwh is offline   Reply With Quote
Old 02-10-2013, 01:19 AM   #3 (permalink)
tx65coupe's Avatar
I had trouble with reproduction motor mounts of unknown brand before too.
I'm using RMP adjustable motor mounts, problem solved.
1997 Cobra Convertible (stock)
1965 Mustang
Late Model 302 and T5 and Versailles 9 Inch
Edelbrock Heads, Cam, Intake, and Carb
JBA Headers and Dynomax Ultraflo Mufflers
http://forums.vintage-mustang.com/me...-100-1108.html
http://www.youtube.com/watch?v=LXk_MVV7V0g
tx65coupe is offline   Reply With Quote
Old 02-10-2013, 02:26 AM   #4 (permalink)
2manyhobbies's Avatar
Send a message via Skype™ to 2manyhobbies
Use a long screwdriver to manipulate the holes to line up, I'm surprised you had one work correctly, your frame must be bent! I've done quite a few over the years and they never quite line up right. Never understood that.
"LAZARUS"
Goodguys Younguys award winner TX-2000
MCA Grand National Pinnacle Award: Best Modified Driven, Sept 2012
Modified Mustang & Ford article: ?/2013
2 years of hard labor later
2manyhobbies is offline   Reply With Quote
Old 02-10-2013, 07:22 AM   #5 (permalink)
ToneMT's Avatar
I had to replace mine also. The 67/68 had something different about the mounts if I recall so I ordered it from GN.... worked fine but spendy.
1968 Mustang Convertible: Restoration Start Date Feb 2012
1964 MGB Restored and supercharged
277 Photos of this restoration (photobucket)
/ 2013 Walk around video
ToneMT is offline   Reply With Quote
Old 02-10-2013, 08:01 AM   #6 (permalink)
The 67 has something different with the mounts and i've read the mounts are expensive to get. The 68 uses the same mount on both sides.
Old 02-10-2013, 08:08 AM   #7 (permalink)
ToneMT's Avatar
yeah the 67 289 and 68 vert 289 (plus a few others) unfortunately used the same mounts...so I got the pleasure of that experience...
Old 02-10-2013, 09:46 AM   #8 (permalink)
22GT's Avatar
There's a lot of really crap mounts out there, that don't really fit anything well. It's worse if you have a 67, or a convertible. Many sellers say they have that mount, but they don't. What they have is the regular mount, reboxed.
The G/N mount is moderately priced, considering the custom work it takes to create them. They fit perfectly, because they are patterned after the original C7ZE mount.
I'll repeat the link kd4pwh posted-
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 02-10-2013, 10:30 AM   #9 (permalink)
ToneMT's Avatar
If you need to order - heres the page to goto:
t
Old 02-12-2013, 01:06 PM   #10 (permalink)
LynnBob 65 Mustang's Avatar
I was looking into getting this kit at CJ' Pony's.
Mustang Motor Mount Kit 289/302/351 11/1/1965-1972 | CJ Pony Parts
Is this a problem child
Or should I just get the RMP adjustable motor mount kit?
Lynn
'99 GT automatic
CDC Shaker scoop, K&N Filter
MAC cat back
Max Speed 1 ½” Lowering springs
KYB GR2 shocks and struts
Cobra front brakes
'65 Mustang coupe in progress
http://forums.vintage-mustang.com/vi...lots-pics.html
LynnBob 65 Mustang is offline   Reply With Quote
