Cam specs and questions HELP! - Page 5 - Vintage Mustang Forums
Old 02-17-2013, 03:15 PM   #61 (permalink)
cmefly's Avatar
Originally Posted by 22GT View Post
Tell ya what. How about he puts in the Rhodes lifters. If there's no change, I pay for them. If, however, he gets a smoother, quieter idle, you pay for them.
Safe bet. I've used Rhodes lifters many times.
Ok, That works for me
cmefly is offline   Reply With Quote
Old 02-17-2013, 03:40 PM   #62 (permalink)
Zudman's Avatar
Don't know about anyone else, but 4+ pages about cams and my head is spinning!. Keep it up I'm learning...
Zudman is offline   Reply With Quote
Old 02-17-2013, 04:24 PM   #63 (permalink)
Think 22GT s going to win this. Had a friend several years ago with a Tiger with a hefty cam...installed a set of Rhodes and man did it ever smooth it out and actually seemed to produce more low end torque.
patrickstapler is offline   Reply With Quote
Old 02-17-2013, 04:25 PM   #64 (permalink)
dm289's Avatar
Originally Posted by Troy10 View Post
Hi everyone. WOW.. I did not think I was going to get this kind of response. Otherwise I would have checked back sooner.
Getting back to my original post.. and i should have been more clear on this. I was merely asking about my CAM what you guys opinions of it were. I really am in no position to change the CAM. I don't want to spend the money to do it, nor do I have the technical expertise to do it myself. I want to change the exhaust to something tamer. However, I've read where that might not help a whole lot if the cam is to aggressive. That's why I posted asking about the cam. Someone asked about my exhaust and headers. I do not know what what they are. I've looked through all my paper work can't find what they are. I did climb under to take a picture which I'm going to try and attach to this post.
Also, someone asked for a sound clip. I do have a youtube clip that they previous owner made when he was in the process of selling the car. Towards the end he'll start the car. It's hard to hear in the video, but there is a lope. And.. I know from the video, you guys will think I'm crazy because I'll admit, it doesn't sound too bad in the video.
video: https://www.youtube.com/watch?v=lkb2...e_gdata_player
Troy10,
Looking at the photo, it appears there is not an H-pipe and or crossover between the 2 sides of the exhaust... the lack of one results in a louder exhaust... having a shop add a crossover would be easy and inexpensive... my opinion I would start by adding one of those and seeing how it sounds, if it is still too loud then replacing your unknown mufflers with known quiet turbo mufflers like Walker Dynomax Super Turbos would be a good start... in a previous post of yours I mentioned Rainbow Muffler in Cleveland... another option would be Mufflers for Less on Pearl Rd near Brookpark in Cleveland... they put a cat back system on my daily driver for $159... they bend all the exhaust they put on so adding a small crossover would be a simple task for them...
dm289 is offline   Reply With Quote
Old 02-17-2013, 04:25 PM   #65 (permalink)
66resto's Avatar
Well I'm obviously not an expert, but what is his best plan here?
Seems like mufflers would be the cheapest, least evasive swap. Find an ultra quiet muffler and see if that makes him happy, knowing that it is a gamble and may have to dig into the motor later...either lifters or cam? Maybe it will be enough to get him by till he is ready for the cam swap if be is still not happy.
How much cheaper would it be for Rhodes lifters (push rods if needed), labor, gaskets, etc. versus a shop swapping out the cam?
1968 Fastback: 331 stroker, FTI cam, N351 Heads with a few upgrades, 4r70w w/3600 stall, 9" locker w/3.70 gears
66resto is offline   Reply With Quote
Old 02-17-2013, 04:29 PM   #66 (permalink)
22GT's Avatar
Originally Posted by 6t9mach1 View Post
So he is going to have to pay for the conversion and pay for new pushrods that are the proper length when he could just toss on a couple of stock mufflers on the thing which will do more for sound then what you are talking about. Sounds like a great plan...go with it.
The stock 65-66 mufflers are smaller than the ones he has, plus they are 2" inlet, while his pipes are 2 1/2". Now that's a great plan.
Instead, he gets the lifters he already has modified, puts them back in with the pushrods he already has, and the car runs the way he wants it to run.
Amateur restorer. (Well, once in a while I have been paid for it)
22GT is offline   Reply With Quote
Old 02-17-2013, 04:36 PM   #67 (permalink)
22GT's Avatar
Well, that's an excellent question.
Since the lifters and pushrods have to be removed either way, that's a wash, labor-wise. Changing the cam requires, additionally, removal of the radiator, fan, fuel pump, harmonic balancer, water pump and timing cover, timing set, and cam. Basically, changing the cam takes a whole day. Coupla mufflers, 1-2 hours, IF the replacements are compatible with the pipes.
If the OP had a set of Flowies, I'd have gone after them first thing. I've driven a lotta Mustangs with Flowies, and I'll never use them. The noise would get old real fast. My other car has straight through mufflers that are quieter than most Flowies. But he's already got big conventional mufflers, I just don't see how mufflers a couple inches bigger will solve his problem. For sure mufflers won't make it idle smoother.
Old 02-17-2013, 04:36 PM   #68 (permalink)
slow-poke's Avatar
I tried some Rhodes lifters with a really lumpy cam I had in a 289, not a huge difference. If compression is marginal for pump gas, these lifters might pose a problem.
N/A 408 c.i. G-Force 5 spd. 10.x through the mufflers
slow-poke is offline   Reply With Quote
Old 02-17-2013, 04:41 PM   #69 (permalink)
22GT's Avatar
Originally Posted by dm289 View Post
Troy10,
You might be right. But if so, we need a better picture of this-
Old 02-17-2013, 04:44 PM   #70 (permalink)
22GT's Avatar
having a shop add a crossover would be easy and inexpensive... my opinion I would start by adding one of those…
I agree, if that thing in the photo is not a crosstube. I'm a big believer in crosstubes. Smoother sound, more power. What's not to like?
Old 02-17-2013, 04:55 PM   #71 (permalink)
If its just a sound issue then I would put an x-pipe on it and mild resonating mufflers. I don't know how this turned into such an in depth cam thread.
csouther is offline   Reply With Quote
Old 02-17-2013, 05:02 PM   #72 (permalink)
22GT's Avatar
Well, my part in it is that I think his car is over-cammed for a cruise-night-take-the-wife-to-Dairy-Queen car. Mufflers will not make the car idle smoother.
And the X pipe, a useful item, will not work as well at low rpm as the crosstube. The OP started this by saying " I want a nice muscle car purr... and this sounds like a dragster".
Old 02-17-2013, 06:06 PM   #73 (permalink)
Maybe the OP should post a video of the car running should everyone here could get a good understanding of what he really is experiencing.
Old 02-17-2013, 06:40 PM   #74 (permalink)
Rebel Racing's Avatar
As a related question...........how important is the position of the crossover--IOW, where is the optimum position and how bad is it if you can't get it there (our case with the AOD)?? If this is hijacking feel free to tell me and I'll make a new thread.
Please Visit Our '93 Mustang Drag Car's Website:
http://www.rebelracing.8k.com
Rebel Racing is offline   Reply With Quote
Old 02-17-2013, 07:43 PM   #75 (permalink)
slow-poke's Avatar
Paint a stripe on the exhaust pipes behind the headers, and make a few high speed passes, where the paint discolors is the ideal location, usually a foot or so behind the collectors.
