Guys,
I have a toploader tranny and i think this gear on the output shaft. Mustang Speedometer Drive Gear 7-Tooth Black 4-Speed Toploader Transmission | CJ Pony Parts
I Will count teeth tonight .If it is what speedo gear do I need.
It looks like the po used the old 17T type 3 gear out of the old auto tranny.From what i can tell mine is a green tooth and is 17T and the type 3 and i can only find them listed for auto's.
This one is chewed up and the cable is cut off.
1970 Mach 351C 4 speed Top loader .Older restoration which i am taking apart and making it right with improvements.
When I bought my 66 a month ago, the previous owner had an automatic gear in there instead of the manual. I bought the manual one (17 tooth white, not sure if its correct tooth count) but now have discovered since the wrong gear was in there, it messed up the other plastic gear inside the trans, so now I have to replace that one also.
This would look familiar, then.
Amateur restorer. (Well, once in a while I have been paid for it)
The gear inside the transmission should be pink (6 teeth) or black (7 teeth). Pretty sure there are only two. Make sure you get the right gear for the cable, 4 spd vs auto. If you put an auto one in you will tear up the gear inside...not fun...ask me how I know....
Well All i know for now is I have a black 7 tooth.That is a start and i do not know what i have for gears and will end up with tires as I need to buy new ones.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
