classic 302 boss engine - Vintage Mustang Forums
Old 02-25-2013, 09:10 PM   #1 (permalink)
snakebite8's Avatar
Default classic 302 boss engine
hey everyone. quick question. i know about the freeze plugs and heads. but is a vin stamped on a boss block like a 289 hipo? looking at a car tomorrow and he says the car has a real 302 block in it. the pic he sent me is not the best but it looks like boss valve covers r on it.
snakebite8 is offline   Reply With Quote
Old 02-25-2013, 09:25 PM   #2 (permalink)
supershifter2's Avatar
unless its a service block it will have the vin. lots of 69's got the sevice block under warranty after the piston skirts cracked.
supershifter2™ < !
supershifter2 is offline   Reply With Quote
Old 02-25-2013, 09:26 PM   #3 (permalink)
If it has the screw in then you can be sure it is a boss or 427 engine. The size difference will tell you it is a boss 302. Vin stamp is on bottom of block but I am not certain that vin is visible with oil pan on. Heads have part numbers that you have to confirm also. There are reports of not all vins being stamped on engines but I doubt it is true b/c it was required by law. If it did happen, then it would be a rare occurance.
Current piles of rust:
1965: New yorker 1968: GTO convert, Lemans convert Porche 911 1969: MustangGT convert, mustang Mach1,GTO convert, Firbird Convert 1970 Boss 302, 1972: Charger 1999:f250 CNG truck 2011:nissan altima Gotta get rid of some of these lol
69DroptopGT is offline   Reply With Quote
Old 02-25-2013, 09:30 PM   #4 (permalink)
BTW, lots of people say they have a boss 302 in the car but dont have them.
Old 02-25-2013, 09:34 PM   #5 (permalink)
Oh and there are 8 bolts holding down valve covers.
Old 02-25-2013, 10:13 PM   #6 (permalink)
snakebite8's Avatar
all 351c heads have 8 bolts,so in theory someone could have but 351c heads on a 302
Old 02-25-2013, 10:48 PM   #7 (permalink)
Very true. These are the head casting numbers. 1969 - C9ZE-6090-A or C 1970 - D0ZE-6090-A or B servicereplacement : D1ZE They are located under then valve covers though.
Old 02-26-2013, 06:13 PM   #8 (permalink)
snakebite8's Avatar
well after looking over the engine it looks like it has boss heads on it, but the engine looks to be just a regular 302. was hard to see because the engine is in a 65 mustang but it looks like the engine did not have screw in plugs. heads r D1ZE90AA
Old 02-26-2013, 06:29 PM   #9 (permalink)
Boss 302 head casting numbers are:
Which figures. It doesn't make much sense to put actual Boss 302 cylinder heads on a regular 302 block. Any set of 351 Cleveland 4V heads will be nearly identical. You need only add screw-in rocker studs and pushrod guides. (OK, the intake valves on the '69 Boss 302 heads were slightly larger. But that's still not a reason.)
Actual Boss 302 heads are very valuable to someone restoring a Boss 302. For anyone else, it's a waste of concours casting numbers.
Klutch is offline   Reply With Quote
Old 02-26-2013, 06:46 PM   #10 (permalink)
snakebite8's Avatar
I thought d1z r also codes for boss heads?
Old 02-26-2013, 07:00 PM   #11 (permalink)
I don't think so. I just checked the Boss 302 registry. They list a "D1ZE" which was for the cancelled 1971 Boss 302.
Old 02-26-2013, 07:04 PM   #12 (permalink)
Originally Posted by snakebite8 View Post
heads r D1ZE90AA
I can't find any reference to that casting number. I'm thinking you weren't able to see it clearly. But I'm pretty sure it's a 351 Cleveland casting number.
Old 02-26-2013, 07:05 PM   #13 (permalink)
This is a 70 boss 302 with a H&M dual quad intake and some other aftermarket stuff
turbo2256b is offline   Reply With Quote
Old 02-26-2013, 07:15 PM   #14 (permalink)
snakebite8's Avatar
No i have a pic of the code . I will post in a little bit and it has d1z
Old 02-26-2013, 07:18 PM   #15 (permalink)
snakebite8's Avatar
I went on the boss reg and the last pic has a heads from 1971 boss 302 with dize
