Power Steering Leak - Page 2 - Vintage Mustang Forums
post #16 of 17 (permalink) Old 08-16-2013, 07:25 AM
replace the seats and the hose. Chockostang has seats. Napa may have them too. One of the seats on control valve are not reproduced (the larger one). You can take that one out put in a drill and sand and scratches out. Don't bother replacing hoses unless you do seats - probably still have a leak.
palerider is online now
post #17 of 17 (permalink) Old 08-16-2013, 07:50 AM
CHOCK's Avatar
The members have given excellent help here, but as Slim indicated using sealant, tape, etc is not effective.
The metal in some hoses is very hard, and needs a great deal of tightening force to get it to "Sink in" the softer aluminum tube seats.
The biggest leaker is the "inside" ram hose on the control valve. Folks tend to put both hoses on the control valve, then try to tighten them. Can't be done. Put the inside hose on first tighten with a open end wrench---Go get your Vice Grips, carefully clamp down on the flats of the nut, turn the dam thing till it screams!
Now install the outer hose, tighten same method.
All the other hoses can be tightened Hell For tight with the vice grips. YES, you can use Vice Grips and not destroy the nut if done properly. Much more leverage this way.
Hope this helps.
Dan @ Chockostang
CHOCK is offline
