Stop fuel spills- Filler neck modification - Vintage Mustang Forums
 1Likes
  • 1 Post By Mach1 Driver
post #1 of 15 (permalink) Old 04-01-2016, 03:26 PM Thread Starter
Mach1 Driver's Avatar
Since this site does not allow the attachment of a MicroSoft Word file this large, you need to follow to this link: https://drive.google.com/file/d/0Bwk...ew?usp=sharing
This will load the first page. If you want to see the entire 9 pages go to the top and click on the download button (its a downward facing arrow). Sorry for this awkward work-around, but so far its the only way to present the material.
SWPruett likes this.
Mach1 Driver is offline
post #2 of 15 (permalink) Old 04-01-2016, 04:07 PM
qbui's Avatar
Thanks for taking the time to write it up and sharing it with us!
1969 Mustang Convertible
302, C4, P/S, P/B, A/C, FiTech EFI
qbui is offline
post #3 of 15 (permalink) Old 04-01-2016, 06:25 PM Thread Starter
You are welcome. Its something that has bothered me since I bought the car in 1969. Now that I'm retired I HAD to fix it.
Original Owner 69 Mach1
post #4 of 15 (permalink) Old 04-01-2016, 08:40 PM
Paul1958's Avatar
Heres one from a few years ago - it requires welding. I recall the guy had a better write up at another site but I cant find it now.
http://www.stangfix.com/threads/fuel-filler-mods.2879/
Paul
Okay. Engine Stop. ACA out of Detent. Mode Control, both Auto. Descent Engine Command Override, Off. Engine Arm, Off. 413 is in.
-Buzz Aldrin, Apollo 11 LMP
Actual first words from the surface of the moon
Paul1958 is offline
post #5 of 15 (permalink) Old 04-01-2016, 08:47 PM
concerning your zinc plating costs...... do it at home with your battery charger
Zinc Plating with Common Materials
the only addition I did was add a 25 ohm, 25 watt potentiometer so I could more accurately control the current.
its really easy & works great.
I'm zinc plating as many parts as I can on my stang for corrosion prevention.
zinc is a sacrificial metal... thats the reason there is a zinc anode rod in your water heater.
minnickb is offline
post #6 of 15 (permalink) Old 04-01-2016, 09:02 PM Thread Starter
I investigated that but the set-up would have cost more than taking it to a plating shop and it would require experimentation...I decided to just take on one project at a time.
post #7 of 15 (permalink) Old 04-01-2016, 09:04 PM Thread Starter
Fuel filler Mods | StangFix.com
Paul
Yes I've seen the solutions that require welding. This doesn't and anyone can do it.
post #8 of 15 (permalink) Old 04-01-2016, 11:53 PM
maladezo's Avatar
Great concept, regardless of how you do it. My filler has been a pain in my *** forever! Cool write up about the zinc plating.
'67 coupe, 390-S, 4spd.
maladezo is offline
post #9 of 15 (permalink) Old 01-11-2017, 11:17 AM Thread Starter
I'll try to add a PDF version here of the original Word.doc to give you easier access.
Nope, even that exceeds the limit, sorry guys.
post #10 of 15 (permalink) Old 01-11-2017, 02:22 PM
Rorin67's Avatar
Excellent job. I really appreciate that you provide part numbers, prices and sources.
Formula for a daily driver street fighter in Los Angeles:
'67 Fastback + Built 351W + T5 + 3.55:1 + LTs + 2.5" + 40s + TT2 17s
+ Shelby drop + CSRP + R&P + Bilsteins + SFCs + under riders + 22 Gal.
+ 3pts + 2nd Skin + MTF grille/lights + LEDs + SiriusXM
MTF Grille/Light Kit Install w/ Pics... & Engine Bay Pics...
As featured in Hot Rod Magazine tech article, May 2014
Rorin67 is offline
post #11 of 15 (permalink) Old 01-11-2017, 04:04 PM
Great write up and pictures. I plan to purchase the filler neck insert you used (thanks for the part number!) and simply weld it in place after cutting the filler neck, then weld the filler neck back together. Before reading this, I planned to insert the drilled plate that was featured on stangfix, but I like this solution much better.
David Eckel is online now
post #12 of 15 (permalink) Old 01-11-2017, 06:38 PM Thread Starter
Originally Posted by David Eckel View Post
Great write up and pictures. I plan to purchase the filler neck insert you used (thanks for the part number!) and simply weld it in place after cutting the filler neck, then weld the filler neck back together. Before reading this, I planned to insert the drilled plate that was featured on Stangfix, but I like this solution much better.
One of the Stangfix guys did what you are describing but we haven't had any updates on the result. By the way, you can get the PDF version over there. The downside of welding is that you need to coat it with something. The filler necks you can buy from places like CJ Pony are painted with a conductive paint, but I couldn't find anything like that. That's why I resorted to zinc plating. I think the metal parts need to be conductive and to be grounded to the chassis. The fuel nozzle can be at a different potential than the car and the charge needs to be bleed off. The fuel sloshing through the inlet can also set-up a static charge. My recommendation is to play it safe, the car manufacturers do it for a reason. Since the flapper is a different material and can't be removed once welded I don't see how you could have it plated.
post #13 of 15 (permalink) Old 01-11-2017, 09:15 PM
Great write up, I was actually discussing this the last week. I'm going to follow in your footsteps.
One questions. Is there a reason why you didn't make the cut a little lower and fit the filler to the upper pipe, and then just use rubber hose from that down to the tank? This would eliminate the need for the grounding strap also.
hus65 is offline
post #14 of 15 (permalink) Old 01-11-2017, 10:28 PM
Davegonewild's Avatar
Thank you for the write up
1964.5 Convertible D Code with factory 4 Speed born July 6th 1964
Davegonewild is offline
post #15 of 15 (permalink) Old 01-12-2017, 08:23 AM Thread Starter
If you look at drawing 1b you'll see that if you move the cut down much it will change the geometry of the fuel nozzle to the filler pipe and you may not be able to push the flapper completely out of the way. You can always try it and let us know what happens. There's always room for improvement.
