Not entirely sure, but it might have something to do with your alternator mount. It appears custom, and higher than normal. Here is my 68 set up. good luck.
It is that way because of the way your alternator is mounted, much higher and the angled hose shown in one of the 68 Mustang is what the one on my 66 looks like. You might consider making that connection serve a purpose, get one of these.
I'm betting there's a Gano filter in that joint. As someone already posted you can get the hose in one piece, but I'm thinking there's a (Gano filter) coolant filter in place. I'm running a similar set-up on my 1965 289 car and just modified the original 65 289 hose to fit. I'll try an post a picture. On the 65-66 Mustangs the alternator is originally mounted flipped down from what you have. Your running a newer 5.0 style thermostat housing which requires the modified hose. Hope this helps
Here's the only picture I could find right now. You can see the original 65 Mustang upper hose mold modified to work with the new style water outlet and alternator mounting.
The engine in your 66 Mustang looks like a 5.0L from a late 80s Mustang and that is the basic routing on the upper hose on those engines - although they are made in one piece per the link above.
The engine is a 302 stroked out to 331, so i take it that is the later 5.0 302 engine ? Like i said i am learning all the time about these cars but we did not have them over here so it is like starting over for me.
Got another question, the car came with the heater hoses removed. I have brought a classic auto air until to fit and just looking at where to refit the hoses.
I can see one outlet blanked off on the pump, the other looks to be taken up by a gauge temp sender in the inlet manifold, can someone confirm this looking at the photos.
At the rear of the inlet manifold is this plug, I have yet to remove it, anyone know if coolant is under it ? Hopefully I can relocate the temp sender to here.
The 'blanked off outlet' on the 'pump' is actually a non-used port on the water outlet neck (not pump) that is threaded and used to mount a sender/sensor in some applications. On your water neck it is not drilled/threaded:
Where you have a sender/sensor on your intake there is usually a straight or right angle water outlet hose fitting that the hose to the heater core goes on (right angle in this example). You can also see a threaded port in the water neck on this engine:
What brand of intake is that? Most have the port for the temp sender on the driver's side front of the intake and the hole on the front passenger side is for the heater hose fitting.
I believe it is a pro comp Typhoon Intake Manifold and yes it does have a port on the drivers side, it has a blank in there so I will remove it and most likely fit the sender for the temp gauge into that one
I did a vintage air install (should be similar to your classic air?) and took a ton of pics. Look here starting on post #91 and it continues over the next couple of pages:
Nice work, that should work well for you. Be careful putting that back together, there should be a recess that the stat rests in, then the gasket and then against the manifold. I worked in an auto parts store many years ago and sold many people a new housing after they had the stat slip out of the groove when putting it together. A few dabs of silicone will hold it in place and make assembly painless. But looking at your tools I''m sure you are already aware of this.
Related Threads
Vintage Mustang Forums
4M posts
89.2K members
Since 2001
