This weekend I removed the stock radiator and flex fan to install my new aluminum radiator from Engineered Cooling Products. Like many, I am having fitment issues with my stock water pump. I've considered low profile water pumps, but they all face the wrong side or require timing covers etc...
I've managed to reverse the fan into a pusher and with a little trimming it will fit in the front. However, I will only be able to put the trans cooler on the inside of the radiator. Will this cause any cooling issues? Does anyone see a better idea? Need some opinions Please!!
This is the radiator in the original setup-you can see the fitment issues...
