Add forward/backward power seats to your vintage Mustang. This power seat kit will bolt on to your factory seat frame and mount to your factory seat riser. You will need to run a fused 12v power wire and ground. I don’t know if it will work on aftermarket seat frames.
Adding this kit to your car will increase your rear seat adjustment travel by 1.25 inches. It has the same forward travel and will add just 1/8 inch to the seat height.
You can use any power window type switch for movement control located anywhere you can mount a power window switch, such as in a console.
The seat switch kit will place the switch in approximately the same location as the manual lever. The switch case comes in black and can be painted to match your seat color.
Power seat track works on drivers or passenger side.
Detailed install instructions are included with the power seat track.
I warranty the power seat for life of the original purchaser.
Power seat assembly without the switch kit for VMF members is $199.00 plus shipping.
Add $50.00 if you want the switch kit.(my cost)
