17's or 18's on a 66 - Page 2 - Vintage Mustang Forums
 1Likes
post #16 of 33 (permalink) Old 04-20-2017, 08:54 AM
Just for reference I'm currently running 17x8" (4.5"BS) with 235/35/17s and a 1" spacer in the front with very little balljoint clearance and very little clearance with the rolled fenders. 17x8" (4.5"BS) with 255/30/17s in the back. Before I did the 8.8 swap I had to run a 1" spacer in the back. With the 8.8 I have about 1 1/2" of clearance on the inside of the wheel and almost no clearance on the outside with rolled fenders. I've read that with the stock 8" rear and the poor mans mini tub you can run up to a 17x8" (4.5"BS) with 275s, but I can't confirm that for myself.
1966 Mustang Coupe - GTS Blue
289, T5 WC, 8.8 Rear End
GETTING TORN DOWN FOR FULL BUILD
ModStang is offline
post #17 of 33 (permalink) Old 04-20-2017, 10:18 AM
17x8 Hurst Dazzlers with 5.67 backspace with 235/45's on all 4 corners. My car runs a wider 9" from a '67, with Street or Track coilover suspension and willwood brakes that widen the track width so no spacers on this car, no rolled fenders and no tire rub so far.
65 coupe GT Tribute 5.0L/5 speed
2001 Lightning #1757
Lightning is offline
post #18 of 33 (permalink) Old 04-20-2017, 10:56 AM
Not to hijack the thread, but how do you like the street and track setup? I'm trying to figure out which system I want to go with. As of now I'm almost certain I'll got with a MII setup since I can buy the whole front clip including the welded subframe (my front subframe really needs to be replaced), but I'm open to a coilover setup like you have.
ModStang is offline
post #19 of 33 (permalink) Old 04-20-2017, 01:48 PM
Sick of Corporations
Not to sound mean....but go check your wheels again. You are not running a 17x8 wheel with 4.5bs AND a 1 inch spacer on the front because a 17x8 wheel with 3.5 inch backspacing would stick out significantly. Most likely you are running a late model offset wheel WITH a one inch spacer which adjusts the BS TO 4.5 and on edit....it appears in your sig pic to be late model wheels.....which would have been 5.5 or so backspacing which is why you have the spacer in the front. AND why you were able to lose the spacer when you added the wider 8.8 rear setup
Here is my POS with 245 40 17 front and 255 40 17 rear
Here it is again with 235 45 17 (they stopped making the 245s I had before and this was the only size I could get, plus the smaller footprint helped with the manual steering and I wasn't really in need of that much tire up front) and 255 40 17 rear
Here is again with 235 40 17 (they were sold out of 45s when I needed new tires ) front and 255 40 17 rear
Here is again with 235 45 17 front and 275 40 17 rear
All using 17x8 4.75BS wheels and I run -1.5 camber in the front in all photos. Fender lips in the front are not rolled. Lips in the rear are. The 275 40 tires didn't work too well for me in anything other than a straight line with my 5 leaf mid eye springs but after I upgrade and put in a watts and a 3 link I could run them anywhere/anytime if i wanted to. AKA the 275s are a tight fit on a lowered mustang and a rear centering device helps to have them not rub on bouncey turns
1965 Fastback 410c AOD - DT
1967 Fastback 347 T5- Cruiser
1968 Fastback 408w T5 - Brute
1991 GT Hatch - Fauxbra
1996 Dodge Viper GTS
https://www.youtube.com/watch?v=0LUK2D0GjdY
dodgestang is offline
post #20 of 33 (permalink) Old 04-20-2017, 01:51 PM
Originally Posted by carguytroy View Post
The brake set up I decided to go with says that I may have to run 18's on my 66. Says some 17's may fit but may have to go 18. I have pretty well decided on Coy's C-67's machined wheels, but I'm wondering if they will even fit. They show 18x8 with 4 3/4 backspace and 18x9 with 5.5 backspace. Any insight?
18x8 4.75 BS should be ok for you front and back. Tire profiles will need to be something around 235 40 18 which will keep you close to the 26 inch tall magic number without going over.
post #21 of 33 (permalink) Old 04-20-2017, 04:36 PM
Lol yup, you're right. I forgot I switched the wheels over. New wheels are 5.5" BS. Good catch.
And the new rear end is about 1 1/4" (from what I can remember) wider on each side. So my wheels now site 1/4" closer to the quarter panel than they did with the 8" and 1" spacer.
ModStang is offline
post #22 of 33 (permalink) Old 04-20-2017, 06:56 PM
Originally Posted by gt350sr View Post
I wouldn't go that far- I had 17x8 on the front of my stock '65 and they rubbed pretty hard- 235/45r17 tires (if I recall correctly) on the wheels Coy's said were a direct fit. I dropped back to a 17-7 with the same tire and they work perfect.
It's a wonder they rubbed that bad. 17x8 with 4.75 backspacing fit well on mine. And if you add some camber you can lower the car a bit. My guards aren't rolled either. I have a few friends with 8's in 4.75 and they fit also.
Were they rubbing on hard turns?
hus65 is offline
post #23 of 33 (permalink) Old 04-20-2017, 07:00 PM
He's right. 4.5" backspacing will need a 1" spacer in the front to clear the ball joints with a 17x8" wheel. .
I don't understand this. If a 17x8 with a 4.75bp clears the ball joint, wouldn't a 4.5bp clear no dramas as it sits a 1/4" further out?
hus65 is offline
post #24 of 33 (permalink) Old 04-20-2017, 09:57 PM
Yes but it puts the wheel/tire closer to the fender
2nd 66 is offline
post #25 of 33 (permalink) Old 04-20-2017, 10:19 PM
Yes. The error was pointed out elsewhere in this thread. He was running a 17x8 5.5 wheel which would hit the ball joint and used a 1 inch spacer to push it out to 4.5 inch BS
post #26 of 33 (permalink) Old 04-20-2017, 10:57 PM
fonebooth's Avatar
the 8" on my fronts are with full TCP coilovers-
the rear 9" are running 275's.. rolled lips- mini tub- 8.8" narrowed- with 9" ends and a 4 link and coilovers--
my car is SUPER low- doesnt rub- i do have room to possibly run 295's with custom wheels
most 65-66 ive seen can not take larger than 255 - leaf spring interference-- or the car has to sit so high the tire can sit out past the wheel lip- that doesnt count ..
Mike
64.5 vert rust free survivor :
Stacked EFI- Ford strokers 347
Hydroboost/InfinityBox /Coilovers
4 link rear w/17 x 9's
13" custom brakes
64.5 Vert (all original sheetmetal)
68 survivor vert- 5.0 AOD wifes driver
http://www.cardomain.com/ride/3363178 64.5 build
www.cartelclassics.com (all will eventually load here)
fonebooth is offline
post #27 of 33 (permalink) Old 04-20-2017, 11:55 PM
Yeah no dramas missed that part
hus65 is offline
post #28 of 33 (permalink) Old 04-21-2017, 07:48 AM
Yeah I have 255s in the back and I might be able to run a 265 but it'd be wicked tight. I'm pretty much outta room on both sides of the tire as it is.
ModStang is offline
post #29 of 33 (permalink) Old 04-21-2017, 01:46 PM
I have 275's on a 18X9.5" in the rear and 235/40 on a 18X8 in the front
1965 Mustang Fastback- 349 clutch killer, 70MM turbo,FiTech Go EFI 8, TMI Sport XR interior,Centerforce DIYAD,18" TSW, Master Power big brakes
Super Ford Magazine cover '99
Muscle Mustangs and Fast Fords Cover '00
Modified Mustang and Fast Ford cover '11
Power & Performance 6/15
SEMA 2014 and SEMA 2017
2006 Ford F250-10" lift, King Coil overs, 6000 watt stereo, 370 rwhp/722 ft lbs tq, smoking 38's and rolling coal
1966 VW Fastback- 17" 8 Spokes, 2276cc cruiser
Iskwezm is offline
post #30 of 33 (permalink) Old 04-23-2017, 11:31 PM Thread Starter
carguytroy's Avatar
Cool! I'm using a 9" rear out of a 57-58 Ford. Will that affect anything?
Troy Arave
carguytroy is offline
