Widest rear wheel for a 69 coupe? - Vintage Mustang Forums
 5Likes
post #1 of 17 (permalink) Old 04-28-2017, 05:03 PM Thread Starter
I'm going to be running a 408w (if i can find a good shop) with afr 205 heads and a custom cam for max power so I need lots of grip in the back.
What size do you guys recommend for the wheels and tires?
I just want the largest I can stuff with fender rolling.
I was thinking about torqe thrust wheels but I'm not set on those yet.
I have a set of cobra brakes for the front so I'll need 17" for the front IIRC
parkersd1992 likes this.
lalojamesliz is offline
post #2 of 17 (permalink) Old 04-28-2017, 07:58 PM
GT289's Avatar
I've got the Dodgestang chart you can take a look at......... it's beer 30 here
and I'm not really willing to interpret his notes but if you send me a PM with
your email, I'll send you his chart.
- Douglas Adams
GT289 is offline
post #3 of 17 (permalink) Old 04-29-2017, 01:07 AM Thread Starter
Did you receive the pm with my email I sent you?
post #4 of 17 (permalink) Old 04-29-2017, 10:50 AM
turbo2256b's Avatar
My 70 has 10 x 15 rims with 295 x 50 BFGs on the back.
lalojamesliz likes this.
turbo2256b is offline
post #5 of 17 (permalink) Old 04-29-2017, 11:08 AM
GT289's Avatar
Just sent it this morning. Got distracted last night........
- Douglas Adams
GT289 is offline
post #6 of 17 (permalink) Old 04-29-2017, 06:00 PM Thread Starter
Thank you
post #7 of 17 (permalink) Old 04-29-2017, 08:26 PM Thread Starter
Did you have to mod anything to fit them?
The chart shows 15x8 with 295 x 50 fit fine
post #8 of 17 (permalink) Old 04-29-2017, 08:37 PM Thread Starter
That chart is so nice! Thank you again gt289!
post #9 of 17 (permalink) Old 04-29-2017, 08:42 PM Thread Starter
I have to go with 17" fronts since I have a set of cobra 13" brakes. I think I remember seeing explorer disk brakes work on my 9" rear but I don't remember seeing a minimum rim size. 17" 225 tires up front and 15" 295's in the rear sounds tempting
post #10 of 17 (permalink) Old 04-30-2017, 11:16 AM
turbo2256b's Avatar
hAS MORE TO DO WITH THE PROPER OFFSET so my wheels are semi custom.
Weld wheels was one company that would do it for a decent price. Have heard rumors they have been bought up and to be discontinued.
I began running 295 50 BFGs soon after they came out and found they worked out best on 10" rims. Their dropping of 275 50s which I used did run on 8" rims really upset me.
I liked these a lot because of their load ratings. Could go off on the evolution of there tires also as they changed tread designs over the years also.
post #11 of 17 (permalink) Old 04-30-2017, 02:28 PM
Just some guy
GypsyR's Avatar
I've got 295/50/15's under my '67 by dint of some wackyness which I wouldn't recommend and am going to redo anyway. I find Cooper Cobras fit just a bit better than BFG's for me. The profiles are a smidge different.
But Turbo, do you know what offset you ended up with? I like 295's and wouldn't mind putting some under my '69 but it will be all stock in the rear except for the rims.
GypsyR is offline
post #12 of 17 (permalink) Old 04-30-2017, 05:36 PM
turbo2256b's Avatar
Sorry cant remember I switched to a old Franklin quick change back in 83 84 in my 70 coupe. The 69 that had the 9" was totaled by a guy that ran a red light. The QC is wider and had to do a major inset. I might be able to get a side wall dim to the inner wheel well. Then you could do some measurements to figure back spacing.
I just purchased some Hankook 295 50 15s for my 87 country squire and 265 50s for the front I LIKE BETTER THAN THE COOPERS which I DISLIKED IN THE WET. The Hankooks are only a few tenths different in side wall and tread widths on the 295s BFGs and 265s are almost the same dims as the 275 50 BFGs .
post #13 of 17 (permalink) Old 05-01-2017, 02:12 AM
Just some guy
GypsyR's Avatar
I can figure it out the hard way if need be, wheel fitment is actually WAY down my '69's to-do list.
At one a time I got a friend at a tire shop to hook me up with bald 295/50's. Goodyear, BFG, and Coopers. Which I used for trial fitting. I didn't know Hankook had any, I appreciate the heads up. The best thing I can say about Coopers is that they have a snake head on the sidewall.
GypsyR is offline
post #14 of 17 (permalink) Old 05-01-2017, 08:24 AM
app01's Avatar
On my 70, I also have 10" wide x 15" with 5.5" BS wheels on my 70 with no issues and plenty of clearance. I am running a drag tire, 28"x10.5x 15", that has a 12.3" section width.
Mach671 likes this.
www.PalmieriConcepts.com custom showboards
10.17 @134(still practicing)
70 Mach 1 w/Boss 460 Stroker Engine-Build http://forums.vintage-mustang.com/bu...ld-thread.html
70 Boss 302-May 70, Dearborn-Build http://www.palmiericoncepts.com/My-M...970Boss302.htm
62 Corvette-Build http://www.palmiericoncepts.com/My-M...roon/index.htm
MCA, MCCNE Member
app01 is offline
post #15 of 17 (permalink) Old 05-01-2017, 10:40 AM
Just some guy
GypsyR's Avatar
Excellent info! Thanks.
If anyone asked me what sections width and offset I am running it's fair to say I haven't a clue. I might try to write that stuff down next time. I observed different section widths on those tires I test fitted but never thought to measure them. Next time.
GypsyR is offline
