454s and tire size - Vintage Mustang Forums
post #1 of 3 (permalink) Old 05-07-2017, 07:39 PM Thread Starter
454s and tire size
Looking for a tire size recommendation. 67 vert, stock suspension, fenders not rolled. Doing the Ultra 454 in a 17x7 and 17x8. The backspacing isn't perfect per Dodgestang, but I see many others running these wheels. 235/45-17 front and 245/45-17 rear?
dan58 is offline
post #2 of 3 (permalink) Old 05-07-2017, 09:19 PM
235 might be a bit much on a x7 wheel 215 or 225 would probably work better
2nd 66 is offline
post #3 of 3 (permalink) Old 05-08-2017, 08:34 AM
cmefly's Avatar
215-50-17 on a 7" wide rim would give you a height of about 25.5" and the 245-45-17 on a 8" wide rim would be at 25.7". That should work if you can find the tires you like in both those sizes. the 225-45-17 for the front at 25" tall. The 235mm wide tire on a 7" wide rim is the max width I would use and would be 25.3" tall using a 235-45-17
cmefly is offline
