16" on a 68 fastback - Vintage Mustang Forums
post #1 of 8 (permalink) Old 07-02-2013, 01:47 PM Thread Starter
zhlange's Avatar
I just want to confirm if this is correct:
16x7 4bs 225/55/16 front
16x8 5bs 255/50/16 rear
I've been looking around and there is no definite answer if it will fit or not. I don't mind rolling the fenders. Car will be lowered 1 inch on all fours with shelby drop on the front (if that matters). Pics will be much appreciated.
zhlange is offline
post #2 of 8 (permalink) Old 08-03-2013, 12:51 PM
I don't think the fronts will fit but I only THINK this. The front BS is too far outboard to fit that tall of a tire into the wheel opening. The rears will be very tall, is that what you want? Mine are 16X7-225/50 fronts and 16X8-245/45 rears. Both with 4 1/2" BS
http://i863.photobucket.com/albums/ab200/aslaned/unnamed_1.jpgChuck Wiltens
MCA Gold card - Modified - Judge
Assistant National Head Judge-3rd Generation
MCA#50308
trkpny2 is offline
post #3 of 8 (permalink) Old 08-07-2013, 03:05 PM
66resto's Avatar
Check out Dodgestang's chart...
The one on the chart used a 50 series tire..24.86 inches tall and yours is 25.74 inches tall...any thought of going with a 50 series up front as well? I would want 4.5" backspacing up front if its available. Here is a link to Wallace Racing if you want to play with some fun online calculators.
I think the rears are ok as well. Your rears are 26.04 inches tall. Do you plan for a slightly raked look or wanting it to sit level? If you went to a 50 series tire up front for fender clearance there would be about 1 1/4 inches difference in tire heights.
Mine are a different look obviously, but they are within a 1/4 inch of each other in overall height (front/rears).
1968 Fastback: 331 stroker, FTI cam, N351 Heads with a few upgrades, 4r70w w/3600 stall, 9" locker w/3.70 gears
66resto is offline
post #4 of 8 (permalink) Old 08-12-2013, 08:56 PM Thread Starter
zhlange's Avatar
I want a raked look. But I decided to stick with the original 14" styled steel wheels that it came out with. Thank you.
(My New) Money Pit
zhlange is offline
post #5 of 8 (permalink) Old 08-12-2013, 09:01 PM Thread Starter
zhlange's Avatar
Thanks. Is that what your picture is? I will keep this set up in mind if I decide to change my mind again. Your stance looks good.
(My New) Money Pit
zhlange is offline
post #6 of 8 (permalink) Old 08-12-2013, 10:08 PM
Red67co's Avatar
I'm running 225/50 in front and 245/50 in rear on 16x8 all around. have had no problems on either end.
Red67co is offline
post #7 of 8 (permalink) Old 08-15-2013, 10:34 PM
Yes, that is the current set up. After SEMA I will be changing the wheel and tire set to three piece 17" wheels.
MCA#50308
trkpny2 is offline
post #8 of 8 (permalink) Old 08-16-2013, 11:11 AM
Myopic
Just for completeness sake, on a 16x7 wheel you can't use 4.5 backspacing on the front, you want to target 4.25 backspace for max tire fit. 4.5bs will contact the upper arm.
1965 Fastback 410c AOD - DT
1967 Fastback 347 T5- Cruiser
1968 Fastback 408w T5 - Brute
1991 GT Hatch - Fauxbra
1996 Dodge Viper GTS
https://www.youtube.com/watch?v=0LUK2D0GjdY
dodgestang is offline
