17Inch Wheel Fitment on 66 Coupe - Vintage Mustang Forums
post #1 of 9 (permalink) Old 07-03-2013, 08:29 PM Thread Starter
I recently purchased a 66 coupe, that has 17x8 rims up front, with 215/45/17 inch tires mounted on them. The backspacing appears to be 4.5 inches. The rear wheels are what looks to be 17x9.5 rims, 9.5W tires mounted on them. Backspacing unknown. These are all four Centerline Billet Hammer wheels. One problem is they rub in the rear when you hit a hard enough bump. I am planning on moving the current front tires and wheels to the rear which should help out in the rubbing department. The other problem is the 215/45/17 tires mounted on the 17x8 rims rubbed in the front when I made a sharp turn and hitting a bump ( as in pulling in my driveway). I then ordered a new pair of wheels for the front, same style, but in a 17x7 inch rim, with 4.25 backspacing. Anyone else have any similar issues? I guess my question is if I mount another set of 215/45/17 tires on the 17x7 inch rims instead of the 17x8 inch rims on the front, I would still have the same tire width either way correct? Im guessing the backspacing change might also help. Also I am not sure if it is the stock height or not. This is the first Mustang I have owned so Im not sure how to go about figuring out what the stock height is.
mauser1111 is offline
post #2 of 9 (permalink) Old 07-10-2013, 09:11 PM
I sort of have a similar situation with my 66 coupe. I kept my 17x8 Bullitt wheels from an SN-95. These have a 4.5" backspacing, and have 245/45/17 tires. They don't fit at all! I see adapters from Mustangs Unlimited, but they're $270! I don't know what to try!
Vertigo is offline
post #3 of 9 (permalink) Old 07-10-2013, 10:12 PM
Sick of Corporations
A 17x8 wheel with 4.5 bs and a 215 45 17 (which probably looks a little stretched on that rim) should not rub. I would spend the money having your alignment checked and your front suspension for wear. If the car has the old alignment specs for bias ply tires it makes the top of the tire tip out when cornering...you want more modern specs with some negative camber
1965 Fastback 410c AOD - DT
1967 Fastback 347 T5- Cruiser
1968 Fastback 408w T5 - Brute
1991 GT Hatch - Fauxbra
1996 Dodge Viper GTS
https://www.youtube.com/watch?v=0LUK2D0GjdY
dodgestang is offline
post #4 of 9 (permalink) Old 08-15-2013, 03:44 PM
65coupe408w's Avatar
17x7 up front 215/45 (3.75bs) and 17x9 out back 275/40 (5in bs)
1965 Fastback- 408w fully forged, GForce T5,9inch....and much more.
2003 Mach 1- Azure Blue, 5spd, IRS, Supercharged @ 10psi 480rwhp
1965 Coupe - SOLD
65coupe408w is offline
post #5 of 9 (permalink) Old 09-09-2013, 11:03 PM
Pynikal's Avatar
fenders rolled?? Tubbed? How much hammering did you have to do the fit that size on a 65 in the rear?
Its fun, when it runs......
Pynikal is offline
post #6 of 9 (permalink) Old 09-10-2013, 09:16 AM
no hammering, not tubbed. just rolled fenders. I am running a nitto 275/40/17 drag radial (they run a little narrow) but they sit flush. I am also lowered and daily drive the car so no rubbing is important.
1965 Coupe - SOLD
post #7 of 9 (permalink) Old 09-10-2013, 12:14 PM
i'm running 17x7 bullitt wheels aswell with 1.25" adapter/spacers with 215/45 and 245/45s, but with granada spindles and a maverick rear.
Lee12609 is offline
post #8 of 9 (permalink) Old 05-18-2017, 08:50 PM
Know this is an old thread but where did you find the 17X7 Bullitt Wheels?
Raven62 is offline
post #9 of 9 (permalink) Old 05-18-2017, 10:21 PM
Bullitt Style Wheel & Tire Package 17" x 7/8" Anthracite 235/245 65/73 Mustang | 17" | Wheels | Wheels & Tires | Mustang | MustangsUnlimited.com
2nd 66 is offline
