1967-70 low profile street-competition engine crossmember - Vintage Mustang Forums
post #1 of 2 (permalink) Old 02-01-2017, 01:20 PM Thread Starter
zray's Avatar
1967-'70 low profile street competition engine crossmember
New low profile crossmember. Will provide an additional one inch of ground clearance vs. our standard crossmember, and made of the same high quality materials. 100% USA steel and USA manufactured.
$239.95 standard model
$259.95 jack pad model
This design was pioneered by Ford in 1969 for the Boss 302 program. It improves on the '67-'70 stock engine crossmember by tying into the lower control arm mounting points, resulting in improved rigidity for the unibody lower front frame section. Helps to stiffen the car right at the control arms where it's needed most. Perfect for cars that alreadty have an export brace and Monte Carlo Bar. Every street and competition high performance '67-'70 Mustang will benefit from this racing front crossmember. Guaranteed to improve steering stability at all speeds.
Features:
1) No interference issues with oil pan.
2) Will clear oil pan if using RM lowering engine mounts. Other cross members will not clear
3) Made from 1.5" steel tubing, same diameter as the stock Ford crossmember, only thicker. Other are relying on smaller 1.375" tubing, or even worse, 1.25" tubing.
4) Steel tubing thickness: 0.125", stronger than the stock and all other aftermarket cross members. Others are using thinner tubing and/or smaller diameter tubing.
5) USA made with USA steel
6) Complete with grade 8 bolts & hardened washers (USA made).
7) priced under the similar competition.
8) 100% money back if not satisfied (not including return shipping)
sold over 200 to Mustang forum members, excellent reviews. 100% satisfaction.
http://forums.vintage-mustang.com/vi...er-review.html
email: [email protected]
Priced the same or less than the crossmembers sold by Cobra Automotive & CJ's Pony Parts, but beefier and better fitting. Unlike those, these crossmembers will fit engines that have been lowered 1/2" with the Ron Morris engine mounts). Will fit most aftermarket oil pans too, such as the vintage Cobra lettered T pan, Avaid road racing pans, Moroso pans, and most Canton oil pan applications
Email: [email protected]
optional model has a round 3.5" diameter jackpad made of 0.25" thick steel tread plate that will fit your floor jack perfectly,
NOTE:. Now shipping with a set of camber plates at no extra cost.
These same crossmembers are also available thru Opentracker or eBay for your connivence.
zray is offline
post #2 of 2 (permalink) Old 02-01-2017, 03:26 PM Thread Starter
zray's Avatar
As always, VMF members will get a $20 discount off of the ad pricing on any crossmember ordered direct.
PM or email [email protected]
Z
zray is offline
