1967 Mustang Coupe to Fastback Conversion - Page 2 - Vintage Mustang Forums
 14Likes
post #16 of 20 (permalink) Old 01-25-2018, 12:40 PM Thread Starter
lowlyslows's Avatar
Hey!
Long time since my last update. I have made some progress. I got both front frame rails positioned, attached to the jig, and partially welded to the floor supports. I have also prepped a bunch of metal and modified how I am going to progress with the car.
I ended up having to remove and disassemble the frame rail assemblies. 1 or both of them were off when I originally welded them in and I wanted to fix it. Plus, it made it much easier to work with just the frame rail instead of the entire assembly. I have also been updating my frame dimensions in SolidWorks and it has been paying out! I do plan to upload the dimensions when I am done repairing the frame portion of the car as well as any additional dimensions that I acquire from the Fastback conversion (i.e. location of the rear seat and trim brackets, not the same on the Coupe).
I have, just now, noticed an issue with the rear of the car (see photos). It appears that one of the rear quarters is a 1/4" higher than the other and looks funny from the rear. I figured that some sort of repair was done to the car. Not a big deal since all the metal is being replaced.
I am almost done editing my latest video! Check it out here: https://www.youtube.com/channel/UC0b...r7z6nemIIzUgyg
Slows
ripped, 4ocious and FRC928 like this.
~Paul
"It's not that you can't do it, you just haven't been able to yet"
1967 Mustang Coupe to Fastback - In progress
Build Channel
lowlyslows is offline
post #17 of 20 (permalink) Old 02-26-2018, 06:30 PM
Hey man I'm going to convert my 67 coupe to fastback also just picked it up last week already disassembled I'm doing all of the bodywork myself, I plan on using dynacorn coupe to fastback conversion kit. Are you going to use new sheet metal or a doner car.
klear_koat is offline
post #18 of 20 (permalink) Old 02-26-2018, 06:36 PM
cobra94svt's Avatar
PM me for some prices on dynacorn sheet metal. Doing this swap on a customers 67 coupe I have in the shop.
Current stable
65 fastback
65 coupe
66 coupe
94 Cobra, on a rotisserie right now
cobra94svt is offline
post #19 of 20 (permalink) Old 02-26-2018, 08:01 PM Thread Starter
lowlyslows's Avatar
Hey! Iím am using all new sheet metal from Dynacorn. Itís worth it in my opinion because you end up with all new metal. You will probably have to play with it a bit to make right but itís good stuff. Be sure to build a jig. Check out my YouTube channel in my sig block.
~Paul
Build Channel
post #20 of 20 (permalink) Old 04-17-2019, 12:16 PM
Derrik Graham's Avatar
I found you on YouTube and posted a few things on there I open the account on here a couple weeks ago I believe and completely forgot about it trying to see if I can get dimensions of your jig. I did post a small video underneath of the comments on YouTube what I’m doing but not everything. I should make a build post.
Derrik Graham is offline
