S - Code Resurrection - 67 390 Coupe Build - Page 6 - Vintage Mustang Forums
 62Likes
post #76 of 81 (permalink) Old 04-24-2019, 07:52 AM
Huntingky's Avatar
lol....I see a pile of lead like that I see fishing weights or new cast .44 slugs.
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #77 of 81 (permalink) Old 05-10-2019, 10:24 PM Thread Starter
melawren's Avatar
Seat risers arrived but like most aftermarket parts they needed some work. The center brace was welded on lower than the rest so it rocked back and forth. Simply drilled the spot welds, clamped it in to place and rewelded.
20190505_151223 by M L, on Flickr
20190505_151910 by M L, on Flickr
Also found some time to vapor blast a few random pieces that I picked up recently. Bumper brackets and subframe connectors. The hood hinge is original to the car.
20190503_162436 by M L, on Flickr
20190503_154529 by M L, on Flickr
Both sides of the rear floor needed patched. You can buy this part aftermarket but it is pretty simple so I just made one.
20190429_113357 by M L, on Flickr
20190429_113407 by M L, on Flickr
20190429_113657 by M L, on Flickr
20190429_115714 by M L, on Flickr
Huntingky and englishman like this.
Current Project: 67 Mustang S-Code Coupe
Next Project: 68 F100 Ranger 360 3spd Factory A/C Lunar Green/White
Future Project: 57 Ford 2dr Sedan 390 tri-power with 4spd.
melawren is offline
post #78 of 81 (permalink) Old 06-05-2019, 03:40 PM Thread Starter
melawren's Avatar
Found an original decklid last week on craigslist. It had a small dent but no rust. Brought it home and blasted it. Had to remove original primer/paint, repaint, bondo, primer and last coat of paint. Under all of that was good metal. I just blasted the topside and shot a quick coat of epoxy primer on it......As a BONUS the underside was untouched and still covered in original Ford Nightmist Blue which is the exact color we're painting this thing when it's finished.
20190601_161132 by M L, on Flickr
20190601_164215 by M L, on Flickr
20190602_111035 by M L, on Flickr
Huntingky likes this.
melawren is offline
post #79 of 81 (permalink) Old 06-11-2019, 10:44 AM Thread Starter
melawren's Avatar
Got a few little things done over the last week or so.
Cleaned the underside of the decklid, removed the old seal and removed all the goo that was holding it on. Prepped it and hit with some touch-up paint that was a great match to the original color. Finally applied the new trunk seal. I will probably go ahead and order a reproduction spare tire decal to finish it off.
20190607_185416 by M L, on Flickr
20190607_182255 by M L, on Flickr
Also got the seat risers installed. I scuffed the e-coat on the underside and shot some enamel on them just to give them a little protection. Before welding them in I also put some sound dampener under them to keep road noise and heat to a minimum. Once the location was measure and marked I sanded off the epoxy primer and applied weld-thru primer in the areas that the seat riser would meet the floor pan.
20190605_115711 by M L, on Flickr
20190605_120810 by M L, on Flickr
20190608_200535 by M L, on Flickr
I'm currently working on prepping and installing the rear seat to trunk divider. I opted to go with a steel version instead of original cardboard style. Currently it is half painted and mocked up getting ready for pilot holes to be drilled. Once it is painted I'll apply sound killer to it as well.
20190610_170902 by M L, on Flickr
20190610_194038 by M L, on Flickr
20190610_194305 by M L, on Flickr
melawren is offline
post #80 of 81 (permalink) Old 06-11-2019, 12:10 PM
Just hope you never lose your trunk key as that was an easy access to the trunk in a pinch! Wes
mustang656man is offline
post #81 of 81 (permalink) Old 06-11-2019, 04:37 PM Thread Starter
melawren's Avatar
Good point!
melawren is offline
