Mom’s “Old Blue” 1965 Fastback, A Daily Driver Build - Vintage Mustang Forums
 42Likes
post #1 of 92 (permalink) Old 12-20-2017, 03:47 AM Thread Starter
My Father and I harnessed “Old Blue” behind the John Deer and pulled it from a barn two weeks ago. This will be my Mom’s weekend cruiser. We dusted off eleven years of accumulative dust from the blue epoxy primer. Beneath the patina is a fairly solid 1965 Fastback. The VIN, 5R09C2XXXXX reveals that this one was born in San Jose California, and was originally equipped with a two barrel 289.
Unfortunately the high performance air filter is a just for show. The intake manifold stamping indicates that the engine originated from a 66, so this isn’t the original C code engine. I’m told the engine ran with a knock, which went away after warm-up. As depicted in the photographs, it’s a leaker. A previous owner added long tube headers and dual exhaust. The front floor supports were crushed, so someone was improperly jacking up the car. There is some floor rust. The car is already equipped with 620 coils and a monte carlo bar.
The C code Fastback has the 5-gauge cluster dash and the pony door lights, indicating that it was a factory pony interior car. It originally came with red and white interior. From what I can tell from the overspray, the exterior was silver blue. The interior was partially restored to black. The seats were reupholstered, but a lot of the red interior components like the kick and door panels were simply painted over. The interior will need some tlc, but it’s a solid foundation.
The car currently has an automatic C4, but judging by the clutch pedal return spring hanging on the pedal box and a wad of tape lodged into the clutch firewall hole, I’d guess this was originally a manual transmission car.
I’m sure more history about the car will be revealed through disassembly. This won’t be a fancy or full rotisserie restoration. The car will be a decent cruiser for my Mom; so it must be reliable with some modern mechanical upgrades for safety. We are thinking 260-290 carbureted horsepower 289, power steering, electric fan, tandem master cylinder, front disc brakes, air conditioning, GT sway bar, mid eye leafs, and my Mom prefers a manual, so T5 it is! Paint and rims to be determined.
image98 is offline
post #2 of 92 (permalink) Old 12-20-2017, 06:54 AM
dobrostang's Avatar
Many would kill for a start that nice, you should start a build post
Israel, Caper50, 2nd 66 and 3 others like this.
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #3 of 92 (permalink) Old 12-20-2017, 07:12 AM
^I'm one of the many ^
Good looking project
2nd 66 is offline
post #4 of 92 (permalink) Old 12-20-2017, 07:20 AM
Israel's Avatar
Welcome, I’ll be following.
Israel is offline
post #5 of 92 (permalink) Old 12-20-2017, 07:25 AM
awhtx's Avatar
Not that it matters but has the car been in your family for many years and was parked in the barn or did you just buy it out of the barn?
Israel and gt350sr like this.
awhtx is offline
post #6 of 92 (permalink) Old 12-20-2017, 07:41 AM
A solid fastback with a V8 and (originally) manual transmission! As said above, many would be envious of such as starting point. And your mother is wayyyyy cool for planning to use that as a daily driver. We want to see the progress on this. Good luck with the restoration
[/SIGPIC]67 Fastback GT -- original colour (Frost Turquoise), original 289 A code engine. Pic is of me and the Mustang taken in May of '67, with original F70-14 Wide Ovals. Same car is now restored to "as new" but 3 speed tranny swapped out for 4 speed back in the mid '80's, with tach dash, original Equalock rear, Koni's, Opentracker UCA, LCA, roller perches and idler arm, roller bearing pedal cluster, Cibie headlights, 4100 carb (old 4300 put in storage probably forever)
jfstang is offline
post #7 of 92 (permalink) Old 12-20-2017, 08:03 AM
That is such a great start. Based on your signature, you and your family have some things figured out. Good taste.
The anvil of reality.
post #8 of 92 (permalink) Old 12-20-2017, 08:31 AM
Caper50's Avatar
Wow that looks like a very solid car and sounds like a nice plan to make it a reliable cruiser for mom. Will be following along.
Caper50 is offline
post #9 of 92 (permalink) Old 12-23-2017, 12:46 AM Thread Starter
It’s A Long Story
I first saw the car about twenty years ago driving around town a few times. I didn’t know the owner. I moved away for College while a distant family member purchased the Fastback and used it as a daily driver for about five years. They parked it around 2006 where it remained untouched until December of 2017. It’s now going to be Mom’s cool Mustang. ☺
Israel and Mr.E like this.
image98 is offline
post #10 of 92 (permalink) Old 12-23-2017, 12:57 AM Thread Starter
Removing The Drivetrain and Pedal Box
My Father and I pulled the drivetrain. I didn’t plug the speedometer port on the C4 housing, hence the tranny fluid puddle on the floor. My Bad. Learning.
Pressure washed with hot water. Moving onto pulling the driver side fresh air vent assembly, pedal box, and fruit jar master cylinder.
It looks like someone did a custom modification to the pedal box. The bearing had some play in it. We will swap for another pedal box that I pulled from a rusted out T code coupe.
image98 is offline
post #11 of 92 (permalink) Old 12-24-2017, 11:14 PM
Consider at least some sort of fuel injection, it is so nice to get in the car and no matter the temp it starts and runs smoothly.
On my wife's 66fb I did the chock o stang front disc kit. My wife's car is like yours, a San Jose built c code 3 speed that at some point had a c4 put in. The car currently has a gt40p injected and 4r70w.
Keep posting, looking forward to the updates.
Huntingky likes this.
bluesix is offline
post #12 of 92 (permalink) Old 01-02-2018, 07:28 PM Thread Starter
Thanks for the feedback. We may do EFI in the future, but the plan for now is to transplant new and unused parts off my Fastback and use some parts that my father already has. Once on the road, I'm sure my Mom will customize further.
image98 is offline
post #13 of 92 (permalink) Old 01-02-2018, 07:32 PM Thread Starter
Pedal Box, Heater, Fresh Air Vent, and Engine Bay
I spent the weekend pulling the fresh air vent and heater box. I media blasted and painted the pedal box.
I installed the Scott Drake roller bearing. I was worried about reinstalling the pedal box with the steering column in the way, but the process was relatively easy after a couple of trials. I bolted the pedal box with the clutch spring attached. I greased the roller bearings with white lithium grease; followed by installing the brake pedal, clutch pedal, washer, and cotter pin. Without the clutch stop attached, I was able to lift the clutch pedal towards the dash allowing me to attach the clutch return spring to the clutch pedal with ease. Last, I installed the clutch pedal stop bracket.
I wire brushed the cowl vents and applied Por-15. Fresh air vent was so rusty and gummed up that it was frozen shut. I disassembled; media blasted, primed, and painted. A little grease and its almost as good as new.
May Dad and I pulled the wiring harness, dried, and sanded the engine bay.
My Dad welded up the small tear in the RH side frame rail. Looks like the RH front apron was replaced in the past. We primed and painted with Eastwood satin chassis black paint. Nothing fancy, but should be a decent daily driver.
The plan is to restore and install one of these full-length consoles. Researching the required and missing parts. Meanwhile, I started on installing a new Classic Auto Air “Perfect Fit Series” in-dash unit. My Dad purchased the AC back around 2004 for another vehicle, but it was never installed so its going in this Fastback. This system uses cables rather than electric monitors. Moving forward.
image98 is offline
post #14 of 92 (permalink) Old 01-02-2018, 08:13 PM
awhtx's Avatar
Is the car's original Warranty Plate still attached to the driver door? Just wondering what the build date may be because I see that you have early '65 engine mounts and your 1" wide rear interior trim does not have the separate end caps that the earliest fastbacks had. How about a photo of the trunk lid torsion rod, especially the right end, because there was an early and a late version of it.
awhtx is offline
post #15 of 92 (permalink) Old 01-02-2018, 10:59 PM
Dang man, you’re not wasting any time. Keep doing what you’re doing!
