67 s code fastback - Page 2 - Vintage Mustang Forums
 7Likes
post #16 of 30 (permalink) Old 03-30-2018, 04:32 AM Thread Starter
Still waiting for parts to be shipped from summit racing. Many parts on backorder since Feb/17.!
Anyway here is an update.
Removed floor . Repaired some rust .
File Type: jpg IMG_20180328_165815-1152x864_1522398720712.jpg (61.2 KB, 72 views)
File Type: jpg IMG_20180328_165835-1152x864_1522398733169.jpg (49.4 KB, 71 views)
File Type: jpg IMG_20180328_165820-1152x864_1522398748885.jpg (61.2 KB, 68 views)
icecube76 is offline
post #17 of 30 (permalink) Old 04-22-2018, 05:33 AM Thread Starter
More metal work
post #18 of 30 (permalink) Old 04-22-2018, 01:09 PM
hsvtoolfool's Avatar
Can you discuss which gas method you are using? What type of
filler rod? If you are brazing, what type of flux is used? How tight
and clean do you get the metal before brazing? I ask because
your spots and rod both have a yellow-brass color which makes
me suspect you are brazing. If so, why did you choose brazing
over welding?
Move along. Nothing to see here.
hsvtoolfool is offline
post #19 of 30 (permalink) Old 04-23-2018, 12:09 PM Thread Starter
Yes brazing , i am using acetylene-oxygen. powder flux , clean to bare metal with wire brush or sanding disc.
did that because the car came from factory with yellow spots , so i thought i should keep it that way .
post #20 of 30 (permalink) Old 04-23-2018, 12:34 PM Thread Starter
post #21 of 30 (permalink) Old 04-24-2018, 12:51 PM Thread Starter
Complete floor pan
post #22 of 30 (permalink) Old 04-24-2018, 02:11 PM
I am pretty sure the big-three manufacturers all used ERW
(electric resistance) spot welders for body assembly. The
only gas+flux soldering process I believe they still used
in the 1960s was the leading done at the roof/quarter joint.
Otherwise, Ford didn't have time for brazing or soldering.
If you found evidence of brass brazing, then I suspect the
car was wrecked and repaired using that process. I've never
personally seen anyone use brazing to repair vital structural
areas like frame rails and floor pans. That's why I was curious
about your methods.
post #23 of 30 (permalink) Old 04-24-2018, 03:47 PM Thread Starter
Brazing the front frame support only . All other spots will be might wealded . I am sure that all panels are original. No signs of any repairs. Except for radiator support .
post #24 of 30 (permalink) Old 05-11-2018, 06:26 AM Thread Starter
New doors . Radiator support and cowl in place.
post #25 of 30 (permalink) Old 05-19-2018, 06:24 AM Thread Starter
New shock tower .
post #26 of 30 (permalink) Old 05-20-2018, 07:10 PM Thread Starter
Almost done with metal work . Next taillight panel .
post #27 of 30 (permalink) Old 06-29-2018, 05:19 AM Thread Starter
Update
post #28 of 30 (permalink) Old 05-11-2019, 03:27 PM Thread Starter
been a while since i posted
car is almost done.
minor electrical work and exhaust to be done.
post #29 of 30 (permalink) Old 05-12-2019, 07:52 AM
Looking good! I too was surprised to see some brazing work going on...glad you welded everything else in place...my 65 outer cowl panel had a spot of brass on each w/s corner area but none elsewhere in the cowl. Rock on!
geicoman58 is offline
post #30 of 30 (permalink) Old 05-12-2019, 08:50 AM
blueovalfan68's Avatar
Car looks great! Highland green?
-Chris
'68 Mustang
347ci that has a lot of neat stuff in it
T5 manual trans, alum driveshaft, 9" w/3.70 gears
Suspension parts from SoT, Global West, Maier Racing, and a few others. Works for me!
TCP manual rack (love it)
EPAS (Love this the most)
VWW V45 wheels (like these too)
SoT 13" brakes (stopping is good)
And I finally got a paint job!
blueovalfan68 is online now
