66 T Code - T is for Transformation - Page 31 - Vintage Mustang Forums
 527Likes
post #451 of 577 (permalink) Old 02-05-2019, 09:24 AM Thread Starter
Turnall's Avatar
Originally Posted by Huskinhano View Post
What Iím understanding is if I buy the 6008 rotors, longer studs and mount them to my disc hubs in back astge original 11Ē rotors were and drill out the threads I could use SoT caliper brackets and be done with it?.
I believe you are correct. You may have to mill the calipers where they mount to the bracket (it's "as cast") since they mount to the opposite side from original. I can take pictures if you don't understand what I mean,
Sounds like you will be able to do the conversion on the "cheap" which of course is determined by how much you pay for spindles, hubs and rotors...
Let us know how it turns out!
Allen
Turnall is offline
post #452 of 577 (permalink) Old 02-05-2019, 10:23 AM
Thanks for the info about milling the calipers. Iíll have to check the ones I have.
Itís not a big priority for me. The stock 72 discs are performing fine for my current use. Less unsprung weight too.
Turnall likes this.
Tom
One thing great about getting older. A life in prison sentence is less of a deterrence
Huskinhano is offline
post #453 of 577 (permalink) Old 02-05-2019, 11:14 PM Thread Starter
Turnall's Avatar
Just getting in from a long day but couldn't wait to try on the hats, rotors and spacers. Everything fits as should and you can see in the 3rd picture I will have to use some shims to get the rotor centered, as expected. The spacers are a tight fit on my hubs as also expected.
The one thing that was a little unexpected is the hats and rotors are shipped as two parts and are not together with the safety wiring in place. I'm sure this is done for you in the full kits so I wanted to point it out that it's not when ordering just the hats, rotors and spacers without the full kit.
Cheers, long day but glad to see everything fits. I'll be calling Shaun to order the pads and brake lines...not sure why I didn't with the rotors and hats, I guess I like keeping the freight companies in business...
Allen
Turnall is offline
post #454 of 577 (permalink) Old 02-06-2019, 06:09 PM Thread Starter
Turnall's Avatar
The pictures show the rotors centered in the calipers and the thickness of the shim/washer I had to use to get them centered. It took the same for both sides...
I need to $.80 to my total...
Allen
Turnall is offline
post #455 of 577 (permalink) Old 02-06-2019, 08:34 PM
Pretty....
patrickstapler is offline
post #456 of 577 (permalink) Old 02-06-2019, 08:52 PM
gikort's Avatar
Those look fantastic. Makes me wish I would have stepped up to the big boy brakes on mine. What's the offset on the rotors?
gikort is offline
post #457 of 577 (permalink) Old 02-06-2019, 09:27 PM Thread Starter
Turnall's Avatar
Not sure. I can measure tomorrow. @Shaun probably knows off the top of his head.
Allen
Turnall is offline
post #458 of 577 (permalink) Old 02-07-2019, 02:08 PM Thread Starter
Turnall's Avatar
Hope this helps...
Allen
gikort likes this.
Turnall is offline
post #459 of 577 (permalink) Old 02-08-2019, 11:10 PM
Thanks for posting all this info Allen. One aspect I could never determine was how the offset of the 6008 rotor mounted on the back of the hub vs the aftermarket hat and rotor mounted on the outside. I was wondering if there were two different offsets possibly in the bracket. The other thing I wondered. The 6008 rotor is a little bit smaller in diameter too, about 5/16Ē Iím thinking and how that effects pad contact. I never even thought about the spacer for the aftermarket hat and rotor to center it on the hub. Great job!
Tom
post #460 of 577 (permalink) Old 02-09-2019, 12:01 AM Thread Starter
Turnall's Avatar
Tom, thanks for the reply. I can only think that the offset is the same between the 6008 rotor mounted to the back of the hub to the hat and rotor mounted on the outside. Just adds up but I was not able to check the 6008 rotors because of the hubs I bought. I think the bracket remains the same which would prove that theory (I've only seen one bracket on any of the well known sites).
I too wondered about the difference in diameter. I hope someone (and maybe I will at a later date) can compare the two.
Kudos to Street or Track on the spacer. It fit like a glove to the hub and the hat. It's beveled so you can start it on the hub and it's a tight fit.
In the end, I caved a bit and spent the extra money for the hats, rotors and spacers. I only say this because I think this can be done cheaper with the route you have taken. The one thing that I find you can't get away from cost wise is/are the brackets. That's ~20% of the cost of this conversion.
Allen
Huskinhano likes this.
Turnall is offline
post #461 of 577 (permalink) Old 02-12-2019, 07:42 AM
Supporting Vendor
Shaun's Avatar
Looking good Allen!
You'll need to spot face the mounting ears of the calipers. As you've found out they mount on the opposite side which has a cast surface. You'll need to make this flat and parallel to the brake rotor.
We also machine off the ridge on the front side of the caliper. You may find left untouched it will interfere with your wheel:
Turnall likes this.
Shaun is offline
post #462 of 577 (permalink) Old 02-12-2019, 07:46 AM
Supporting Vendor
Shaun's Avatar
Shaun is offline
post #463 of 577 (permalink) Old 03-06-2019, 07:47 PM Thread Starter
Turnall's Avatar
Picked up the block today. The crank has been 0 balanced, rods and pistons are mated, the block has been honed to the pistons and rings and the work will begin soon.
A pile of parts right now, hopefully to become a monster.
Allen
Israel, Caper50, subpar63 and 4 others like this.
Turnall is offline
post #464 of 577 (permalink) Old 03-09-2019, 08:13 AM Thread Starter
Turnall's Avatar
The machine shop installed the piston pins and spiral locks.
I have to do the rings (I think this is a bit tight...lol). According to the guideline, I should be about .022" on the top rings. I will file each ring to spec and mark it for the cylinder. I need to find a good ring filer...
Allen
Turnall is offline
post #465 of 577 (permalink) Old 03-09-2019, 07:10 PM Thread Starter
Turnall's Avatar
Had some time this evening to tap out the block holes...I'm one that doesn't subscribe to the "thread chaser" theory instead of a tap.
I had two broke oil pan bolts and decided to use a broken punch to try and unscrew them. I found that it was simply black silicone in the holes...SCORE!
Allen
Turnall is offline
