2 years into my 66 FB build - Vintage Mustang Forums
 31Likes
post #1 of 48 (permalink) Old 01-11-2019, 12:26 AM Thread Starter
Budstoy's Avatar
So I have been working on a 66 fastback C code for just over 2 years now and I'm finally at the point where it's starting to look like a car again. It's the classic build story... it started as a mostly complete car that I was going to get running and work on it as I drove it.
My first purchase was a fuel pump and battery and got the car running out of a gas can then I drove it a few miles only to discover it pulled to the right when going down the road and then hard left when I applied the brakes. Next purchase was an alignment tool and I corrected the pulling to the right and the braking pull to the left was greatly reduced. Checked the alignment once again and it was out of spec. After that I took a closer look at the suspension and found that everything was worn out.
That's when I started reading posts on this forum and that lead me to research how to improve and rebuild the front suspension. It looked pretty good on the outside... from 20 ft away! Here a a few pics of what I started with.
Huntingky likes this.
Budstoy is offline
post #2 of 48 (permalink) Old 01-11-2019, 12:53 AM Thread Starter
Budstoy's Avatar
So after reading "how to make it handle" on VMF I had to purchase an export brace and a straight bar.
Budstoy is offline
post #3 of 48 (permalink) Old 01-11-2019, 01:00 AM Thread Starter
Budstoy's Avatar
Then after reading more posts on VMF I realized that I needed torque boxes so I started to put those on... but wait I read another cool post about adding stiffness to your car by installing convertible inner rockers. I figured now was the time to add both.
Budstoy is offline
post #4 of 48 (permalink) Old 01-11-2019, 01:41 AM
Looking good. Nice work on installing the convertible inner rockers and 2 piece torque boxes. I guess that means you will be buying new kick panels, door sills, and will be trimming the fastback fiberglass rear inner quarter panels. What are your plans for the suspension?
image98 is offline
post #5 of 48 (permalink) Old 01-11-2019, 07:25 AM
Israel's Avatar
Iíll be following.
Friend,......."Dude, thatís a rusted pile."
Israel is offline
post #6 of 48 (permalink) Old 01-11-2019, 07:48 AM
Huntingky's Avatar
Following this build
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #7 of 48 (permalink) Old 01-11-2019, 12:11 PM
rpm
rpm's Avatar
Nice work, and 66. Ya, that while you're at it syndrome has bit quite a few of us.
Bob
There are 2 types of people, those who own pickups and those who borrow them.
69 M code Mach 1, 393w AFR 185, AOD trans, 3.50 traction lok N case, 13" 01Cobra 4 wheel disc, QA1 4 wheel coil covers, Chromo tube susp arms, Triangulated rear arms, Convertible inner rockers & seat riser, 8 point roll bar.
Build Pics http://s782.photobucket.com/user/rob...?sort=3&page=2
Build Thread
http://1969stang.com/forum/index.php...bitch-is-back/
rpm is offline
post #8 of 48 (permalink) Old 01-11-2019, 05:58 PM Thread Starter
Budstoy's Avatar
I determined the front inner fender aprons were replaced at some time. I ended up removing the front driver side inner fender and the radiator support and replaced those parts with better Dynacorn parts. Before I re-attached the radiator support I spent some time smoothing out the inner fender panels. I added the gussets that tie the shock towers to the frame rails then I welded in the extra plate where the export brace mounts to the cowl. Besides some additional welding of suspension parts that were spot welded my front end should be optimized pretty well now.
Budstoy is offline
post #9 of 48 (permalink) Old 01-11-2019, 06:26 PM Thread Starter
Budstoy's Avatar
After sorting out the sheet metal in the engine bay and strengthening the front suspension mounting points, I read another interesting thread on VMF called "the best 200 mod ever" and after reading the 70 plus pages I just had to try that on my car. I ended up using the Toyota electric power steering parts and have a lot of info on that swap. I was real happy how that turned out because I kept everything that came stock on the car plus the motor is very well hidden.
Caper50, image98 and andrewb70 like this.
Budstoy is offline
post #10 of 48 (permalink) Old 01-11-2019, 06:46 PM Thread Starter
Budstoy's Avatar
Updating the master brake cylinder, adding a hydraulic clutch master cylinder, plumbing new brake lines for adjustable proportioning valve and making new lines for the 4 wheel disk brakes. A couple pics of the engine bay in primer. I left the radiator support off until the very end. That it made it much easier to get in the bay and do the body work.
Budstoy is offline
post #11 of 48 (permalink) Old 01-11-2019, 10:22 PM
When you decide to do things, you do them all the way! Looks good.
BlakeTX likes this.
jgrote is offline
post #12 of 48 (permalink) Old 01-12-2019, 12:55 AM Thread Starter
Budstoy's Avatar
Thank you, I did trim the fiberglass inner quarters I didn't have to trim off too much material to meet up to the convertible inners. As far as the suspension for the front I decided to do most of the common updates to the stock suspension. One inch Shelby drop, roller spring perches, adjustable lower control arms with rod ends, adjustable strut rods with rod ends, 1 inch anti roll bar, 620lb 1 inch lower springs, Bilstein shocks, quick steer idler arm and drag link, 16:1 steering box and a bump steer kit. It has about 3.5 turns lock to lock with EPS, should be fun to drive. For the rear I just went with 4.5 mid eyes so pretty standard in the back.
Budstoy is offline
post #13 of 48 (permalink) Old 01-12-2019, 08:51 AM Thread Starter
Budstoy's Avatar
Another suspension component I forgot to mention is the ZRay cross member. It was the first thing I purchased when I started on the upgrade and is a really sturdy part to tie the lower control arms together
Budstoy is offline
post #14 of 48 (permalink) Old 01-12-2019, 02:18 PM
I like what you did there. Clocking the motor "up" really tucks it up out of the way
Andrew
My YouTube Channel. Please subscribe.
Instagram @projectgattago
andrewb70 is offline
post #15 of 48 (permalink) Old 01-13-2019, 03:20 PM Thread Starter
Budstoy's Avatar
Andrew
Now that I have it mounted in the car (for hopefully the last time) everything does just fit with enough room for the vent and emergency brake. I mounted the controller on the wiper motor frame and the wire that goes between the EPAS and the controller plugs in like it was made for the car.
Grabber70Mach and andrewb70 like this.
Budstoy is offline
