66 coupe build - Page 2 - Vintage Mustang Forums
 10Likes
post #16 of 29 (permalink) Old 03-24-2019, 11:19 PM
Originally Posted by 2nd 66 View Post
Actually NOT all Shelbys got the UCA drop. Moving into the 66 model year it was axed as a cost/time saver
It was a bit into 66 wasn't it? Like a running change..
Rowdy is offline
post #17 of 29 (permalink) Old 03-24-2019, 11:26 PM
something like that
2nd 66 is offline
post #18 of 29 (permalink) Old 03-25-2019, 09:04 AM Thread Starter
something like that
How was it a cost saver? Just the fact that their tooling has to be different for hole locations? It almost seems like an irrelevant cost saver if so. Ha. Just my two cents. But glad the understanding is still out there so we can all jump on board.
tuckin22 is offline
post #19 of 29 (permalink) Old 03-25-2019, 06:53 PM
labor
Rowdy likes this.
2nd 66 is offline
post #20 of 29 (permalink) Old 03-25-2019, 07:33 PM Thread Starter
labor
Got ya.
tuckin22 is offline
post #21 of 29 (permalink) Old 03-25-2019, 07:35 PM Thread Starter
Side note I got an ignition switch and tried starting the old 6. Wont stay on. Sounds like it’s not keeping the fuel running through it. Maybe the pump or the carb. I would add a video but it doesn’t seem to let me. Not all that exciting. Just a shot of the windshield while trying.
tuckin22 is offline
post #22 of 29 (permalink) Old 03-26-2019, 08:56 PM Thread Starter
Every time I decide to inspect some more. I find that there will probably be more dollar signs out the door to replace/repair stuff.
Not sure what these areas are called but it is where the inner fender/strut towers attach to the floor pan/firewall. Pass side looks pretty gone. But driver side doesn’t appear all that bad. First pic is pass side. Second is driver.
That pretty typical for these cars?
On the positive side I got the center console, shifter and clutch linkage out.
File Type: jpg A63F1013-97AC-467E-A679-3AAA713BCA10_1553648030081.jpg (363.2 KB, 3 views)
File Type: jpg 6BF5D5EC-1438-4FE9-8DBB-0DB6605FA823_1553648046923.jpg (418.6 KB, 3 views)
File Type: jpg C43AB9C7-C4C6-46D1-B504-46A5312545DA_1553648068267.jpg (439.9 KB, 2 views)
File Type: jpg 253ED30D-303D-465D-9C23-592FDA154518_1553648083000.jpg (366.4 KB, 2 views)
Huntingky likes this.
tuckin22 is offline
post #23 of 29 (permalink) Old 03-27-2019, 07:25 PM Thread Starter
Got some brown truck presents today. However, coil springs and motor mounts were not in the packages. We will see if they are going to ship them at a later date.
File Type: jpg 4351C805-32E0-4149-831C-42C6832B478D_1553729116920.jpg (581.2 KB, 6 views)
2nd 66 likes this.
tuckin22 is offline
post #24 of 29 (permalink) Old 03-28-2019, 12:45 PM
65fstbpieces's Avatar
Time for the Arning drop! 1/2" drill bit and template. This inexpensive mod is the best thing I did to my 65 along with a new alignment. -1 degree camber, 3 degrees castor ...........check out Opentracker or Street or Track website for modern alignment specs. Will be following your project. Bill
2nd 66 likes this.
65fstbpieces is offline
post #25 of 29 (permalink) Old 03-31-2019, 05:02 PM Thread Starter
Well. I thought I was fairly set about using a all new 9” off of eBay or going the 8” route. But I decided to go the explorer route. Just over $100.
Looked at the door and I saw a D4 code which I believe is a 3.73 LS.
There are still courteous people out there as well. There would have been no way that I could have lifted that thing in the back of my truck by myself. Bad thing about lifted trucks.
I have some guys that narrowed a GM 10 bolt for me a while back. They were a little expensive but they are good folks. They also had to pull it off the truck at the time so may have been why it was so much.
I also had to buy me a cordless impact so I could work in the junkyard without killing myself. So handy out there.
File Type: jpg 9A93C2A2-A957-4C24-BF07-BD2FF090FB77_1554066044576.jpg (384.7 KB, 4 views)
File Type: jpg FB91E570-8244-4DC5-B1E0-B0B693C60312_1554066298585.jpg (391.1 KB, 4 views)
tuckin22 is offline
post #26 of 29 (permalink) Old 04-07-2019, 08:48 PM Thread Starter
Got one of the fenders off. Took a few hours. The back bolt under the car got sized to the nutplate. Finally took the air chisel to it and it fell out. Are these things pressed in from the factory?
File Type: jpg 1AF385B0-48CA-441F-BF2F-46ED68CC814F_1554684478078.jpg (576.3 KB, 3 views)
tuckin22 is offline
post #27 of 29 (permalink) Old 04-07-2019, 09:07 PM
Time to clean all that old under coating off and investigate
looks like fun about to happen
yes that nut is pressed/welded to the rocker I need new ones as well someone torched mine before I got it https://www.cjponyparts.com/fender-t...xoCBRwQAvD_BwE
2nd 66 is offline
post #28 of 29 (permalink) Old 04-08-2019, 05:33 PM Thread Starter
Thanks for the link 2nd 66. I wonder if those nuts will function the same if minted inverted from the outside of the rocker, or if they will protrude too much.
I have been thinking about how to approach this in the most efficient way. I was going to go ahead and swap out all the suspension now but with the rearend still needing to be narrowed, and still needing from brakes as well as all new steering I may wait to pull the 6 cylinder suspension.
I might just pull engine and trans and mock up the new stuff to make sure everything is good, get headers and all that jazz lined out. Then pull all interior and the rest of the car apart except suspension and send it to be blasted.
Once I get it back I will do a final test of everything and have all the new parts ready to go. Might save me a bit on the initial pocketbook spending by a few months.
Also motor mounts are still a few weeks out. They are currently manufacturing them.
Anyone want this straight 6 and 3 speed? I don’t really have the space to keep it lying around. Would put it up for sale but I don’t have the post count yet and I doubt I should charge anyone for this thing. In the OKC area.
tuckin22 is offline
post #29 of 29 (permalink) Old 05-12-2019, 02:54 PM Thread Starter
Been making slow progress.
Got the engine and trans pulled out of this thing. Engine was completely gone. Pushed water. Oil looked like chocolate syrup. Although the coolant was clean. Kind of strange.
Also got all of the removable glass out. Complete pain in the ace.
File Type: jpg 40728E62-165A-43DD-92A2-FE2A4508708D_1557687066498.jpg (495.6 KB, 5 views)
File Type: jpg 101A711D-718F-48BC-9048-A21DBE893C5E_1557687083666.jpg (460.2 KB, 6 views)
File Type: jpg 0A4F4F41-FBE9-433D-BE43-2757270B6F5B_1557687114672.jpg (381.0 KB, 5 views)
File Type: jpg 82042317-43DC-43DB-84D0-5847F175773D_1557687133308.jpg (372.0 KB, 5 views)
File Type: jpg B580CB5C-3FF8-49AE-BA31-873F8AAB41D6_1557687143398.jpg (329.5 KB, 5 views)
File Type: jpg 7A4E5398-36A3-40B9-B441-A7651E01D57C_1557687155680.jpg (524.9 KB, 5 views)
Rowdy likes this.
tuckin22 is offline
Similar Threads
'65 A-code coupe build AutoAnatomy Build Forum 64 05-16-2019 12:49 AM
15 Years Later a '66 Coupe Build UnderControl Build Forum 33 04-19-2019 03:04 PM
66 Coupe Build from the 80's Il66 Build Forum 22 01-02-2019 06:52 AM
Gambler 500 1966 Coupe Build MuleStang Build Forum 54 08-14-2018 04:54 PM
1966 Coupe RestoMod Build Bobsky Build Forum 40 04-03-2018 05:07 PM
