69 S code Mach 1 - Vintage Mustang Forums
 2Likes
  • 2 Post By ssjohns423
post #1 of 7 (permalink) Old 05-13-2019, 01:39 PM Thread Starter
ssjohns423's Avatar
69 S code Mach 1
Hey everybody, I just picked this 69 S code Mach 1 up. It has spent almost its entire life in Arizona and California so it is a RUST FREE! survivor. It looks as though the engine and trans have never been removed at all. (Even the dirt and grime looks like its 50 years old). I wont know for sure until I dig a little deeper down the road.
I do know that i will be replacing the old front suspension, leaky power steering and drum brakes as soon as i can just to make it safer to drive. My plans are for it to be a nice quality driver that i can drive to the local car shows. Ill post more pics when I get farther along. Let me know what you think.
Scott
Turnall and jonk67 like this.
ssjohns423 is offline
post #2 of 7 (permalink) Old 05-13-2019, 01:59 PM
Welcome Scott, welcome to the madness, looks like you got one in great shape for a good start. For suspension I'd suggest looking at Open Tracker Racing products. He makes some really good stock replacement parts that are improved to ride better and drive better than stock for not much more like his Street performance UCA and roller spring perches. https://opentrackerracing.com/
Can't recommended John at ORP enough, great products and testing that make your car more responsive and let the suspension do its job w/o binding.
'67 Coupe Candy Apple red/red interior; original 289 stroked to 333ci; AFR 165cc heads; built AOD; 9" diff; T/A paint scheme planned.
jonk67 is offline
post #3 of 7 (permalink) Old 05-13-2019, 03:46 PM
Welcome, nice find on the 69 Mach 1. When I bought my 70 Mach 1 in CA, the seller thought it was rust feel as well. After digging in and deconstructing the car I found the lower cowl panel was swiss cheese. I suggest pouring some water into the cowl and seeing if you have any leaks.
Alan
1970 Mach 1 Coyote powered restomod in progress. Started 10/2016.
http://forums.vintage-mustang.com/bu...mod-build.html
2017 Mustang GT AT donor purchased 9/2017.
FFR MK4 sold 3/1/2018.
Boss5Oh is offline
post #4 of 7 (permalink) Old 05-13-2019, 04:46 PM
happystang's Avatar
I've seen that car in person at a few shows as well as for sale on Craigslist. Super solid from what I remember! Good luck on the build.
1969 Convertible field find (450hp spaghetti noodle)
1968 Fastback (428 and a 4 speed)
www.SaveClassicCars.net
-Armon
happystang is online now
post #5 of 7 (permalink) Old 05-13-2019, 08:10 PM Thread Starter
ssjohns423's Avatar
I have 69 coupe also and that was one of the problem areas on that car so..I have already checked that spot off of my major problem areas to look for ďcancerĒ. I need to get it up in the air so I can scrape the red Arizona dirt from the underside. The only main problem I have found so far is that both doors were patched on the bottoms, the PO never cleaned out the drain holes in the bottom of the doors and then removed all of the beltline weatherstripping from both doors! 🤯 Needless to say they both had water in them when I picked the car up.
post #6 of 7 (permalink) Old 05-13-2019, 08:15 PM Thread Starter
ssjohns423's Avatar
Thanks, Iím really exited to finally have a Big Block Mach 1 to play with. Especially one this solid. I still donít know if Iíll leave the patina as is but it is starting to grow on me. Only time will tell...along with the bank account!
post #7 of 7 (permalink) Old 05-14-2019, 01:55 PM
Israel's Avatar
Iíll be following.
Friend,......."Dude, thatís a rusted pile."
Israel is offline
Similar Threads
390 "S" automatic code engine help ? banaestes Vintage Mustang Forum 7 02-27-2019 11:11 AM
1969 Ford Mustang Mach 1 390 S Code Numbers Matching Fastback - $43500 (Simi Valley) rgoudsward 1969 through 1970 Mustangs For Sale 2 01-29-2019 02:30 PM
Trim code "42" on 1966 Mustang Convertible??? glennleeder Vintage Mustang Forum 10 10-29-2018 06:49 AM
Congratulations to Diane (Jeff Tepper's friend) patrickstapler Ride Of The Month Winners! 4 10-03-2018 07:31 PM
69 mach 1 Q code and sportsroof Q code projects vanscooter 1969 through 1970 Mustangs For Sale 3 07-17-2018 07:59 AM
