Next phase for the 66 coupe - Page 28 - Vintage Mustang Forums
 19Likes
post #406 of 417 (permalink) Old 07-10-2019, 09:09 PM
NEFaurora's Avatar
Tony Kovar
1965 Mustang Convertible 200cid I6, 3spd Manual (Soon to be swapped for a '65 Date Coded C4!)
MCA#70001
Getting Ready for the 2020 Melbourne, FL MCA Nationals!
NEFaurora is online now
post #407 of 417 (permalink) Old 07-10-2019, 09:57 PM
Man that sucks...sorry Shaun. Might I suggest...
Lozano Brothers Porting - Winning Engine at the 24 Hrs of Daytona
patrickstapler is online now
post #408 of 417 (permalink) Old 07-10-2019, 10:11 PM
Turnall's Avatar
Originally Posted by Shaun View Post
It was all going so well until it wasn't... Not a very dramatic ending to this motor but none the less, it appears toast.
Wow, that seemed like an unusual place for the engine to let go, out of the throttle and not high rpm's (if I'm hearing the video correctly).
Have you decided if it was a valve that let go or something else?
Allen
Turnall is offline
post #409 of 417 (permalink) Old 07-10-2019, 11:40 PM
Bummer ,I know that sound pretty well
Shaun likes this.
2nd 66 is offline
post #410 of 417 (permalink) Old 07-11-2019, 09:22 AM Thread Starter
Supporting Vendor
Shaun's Avatar
Allen
Speculation at this point because its not fully apart yet but its looking that way. Either valve head broke off and destroyed the piston or the valve got stuck in the guide and the piston smashed into it.
Should be out and at the shop tomorrow so I'll know in a few weeks how bad it is and what I'm in for $$$.
Turnall likes this.
Shaun is offline
post #411 of 417 (permalink) Old 07-11-2019, 10:02 AM
j persons's Avatar
Sorry for your loss, but those Ford crate engines are essentially street engines. I don't know who assembles the Ford heads, but I would be looking at what parts were used. PowerNation TV just built a 363 using a Dart block as an endurance engine for a road race team that should be able to withstand just about any abuse.
My air compressor just blew up and made more of a racket than that 363 when it let go.
F-150 SCab daily driver
j persons is offline
post #412 of 417 (permalink) Old 07-11-2019, 11:54 AM Thread Starter
Supporting Vendor
Shaun's Avatar
Yeah, I'm bummed. I don't even have a KABLAMO video to share... According to those behind me apparently there was plenty of smoke!
Shaun is offline
post #413 of 417 (permalink) Old 07-11-2019, 12:10 PM
Huntingky's Avatar
That really sucks...BUT....you DO have the $6 mill don't you?!
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #414 of 417 (permalink) Old 07-11-2019, 12:34 PM
kketell's Avatar
When my FRPP create dropped a valve it made no noise either.
The problem with mine was the friction welded valve that let go. What a mess...
-Kent-
It's your car, dammit.
Do what makes you happy
kketell is offline
post #415 of 417 (permalink) Old 07-12-2019, 09:02 AM Thread Starter
Supporting Vendor
Shaun's Avatar
More money and better components will fix it I'm sure!
Motor is going into the shop today and a new plan will be formed.
Shaun is offline
post #416 of 417 (permalink) Old 07-12-2019, 10:53 AM
Yeah, it's funny sometimes, I made a 3-piece crank out of my Formula Ford 1600cc, all I heard was a muted thump. No smoke, fire or anything, just went from 7k to dead silent !
'65 A-code coupe, T-10 4-speed, 8" 3.25 limited slip
stephen_wilson is offline
post #417 of 417 (permalink) Old 07-13-2019, 08:03 AM Thread Starter
Supporting Vendor
Shaun's Avatar
Dropped the motor off at Survival Motorsports today. On initial inspection Barry thinks a rod let go.
Most of the motor looks trashed unfortunately. The block may be salvageable with a sleeve, the crank may get saved, maybe one head. The rest is door stops and paperweights.
Huntingky likes this.
Shaun is offline
