289 Block / Crank / Rods, E5 Big Valve Heads - Vintage Mustang Forums
 1Likes
  • 1 Post By bbmach
post #1 of 4 (permalink) Old 02-23-2019, 07:27 PM Thread Starter
bbmach's Avatar
Time to clean the garage of 289 small block Ford parts:
A lot of potential here and a good start, but unfortunately not with me as I have too many other projects. I would love to see the dated block go to someone that it can help.
The Block: C5AE – build date January 24, 1967 - .030” overbore
The Heads: E5AE – Modified by Indy Cylinder Head (also known as Aerohead Racing). 1.90” intake valves, 1.605” exhaust valves (1985 heads originally with 1.78/1.46 valves. Chamber size 67.5-70.5 cc)
The Crank: 289 – Standard Journals Main and Rod
The Rods: 289 C3AE-D
The block is clean, the heads unused. Crank is ready to be used.
Needs:
The cylinder heads were bought new in the late 1990’s for a 289 engine I built, but I wasn’t happy with the way they looked when they showed up. See the photos. The big valves were installed, but the heads weren’t ported under the valves to take advantage of bigger size so I used another set.
I also have pushrods, new lifters, a second set of new valve springs, a new double roller timing chain, front cover…
$300.00 obo - Located in Atlanta and I need to the room!
1969 Mach-1 Mustang
460 / C6 / 9"
Back in Dixie DSO 22 (Charlotte)
bbmach is online now
post #2 of 4 (permalink) Old 02-26-2019, 10:39 AM
ugh....tempted....and local too......
bump.
katwalk is offline
post #3 of 4 (permalink) Old 02-26-2019, 03:39 PM Thread Starter
bbmach's Avatar
Was the bump more for you or me :-) :-)
I'll shoot you a PM!
1969 Mach-1 Mustang
460 / C6 / 9"
post #4 of 4 (permalink) Old 03-03-2019, 10:45 PM Thread Starter
bbmach's Avatar
And... off to a good home!
katwalk likes this.
1969 Mach-1 Mustang
460 / C6 / 9"
Similar Threads
289 heads long block frozen up RTM Engine and Drivetrain Parts For Sale 5 02-21-2019 04:15 PM
Gt40 heads on a pre-h.o block: Steam-holes, a guide and walk-through Scarlet-302 Vintage Mustang Forum 14 10-28-2018 05:30 PM
Having 289 heads rebuilt Bella Vintage Mustang Forum 5 08-24-2018 03:53 PM
Valve Train Geometry on 66 289 markb0729 Vintage Mustang Forum 49 05-28-2018 12:19 PM
Brake distribution block / differential valve. JRFox Vintage Mustang Forum 7 04-16-2018 07:26 AM
