Wanted: Stock 289 rocker arms - Vintage Mustang Forums
 1Likes
  • 1 Post By NEPM
post #1 of 11 (permalink) Old 03-03-2019, 10:40 AM Thread Starter
xcelr8's Avatar
My current rocker arms are pretty worn on the tips and need replacing. I'm not building a crazy engine, just a slight bump over stock for now. It's nuts what they want for new OE rockers out there.
Anyone have a nice used set they would sell? Stud type mount with the ball and nut.
Thanks!
Watch the progress on my 66 coupe here,
http://photobucket.com/projecttetanus
xcelr8 is offline
post #2 of 11 (permalink) Old 03-03-2019, 11:40 AM
gikort's Avatar
Thanks!
I might still have a set you can have if i didn't already toss them. Message me so I remember to check tonight.
gikort is offline
post #3 of 11 (permalink) Old 03-03-2019, 12:28 PM
Rail type or slotted pushrod type heads?
rose62 is online now
post #4 of 11 (permalink) Old 03-03-2019, 02:42 PM Thread Starter
xcelr8's Avatar
That would be great! Message on way.
These are pushrod style. Pic of my rebuilt head and one of the rockers that came off it.
xcelr8 is offline
post #5 of 11 (permalink) Old 03-03-2019, 09:09 PM
gikort's Avatar
Guess I got rid of them. I cant find them anywhere. Sorry!
gikort is offline
post #6 of 11 (permalink) Old 03-03-2019, 09:23 PM Thread Starter
xcelr8's Avatar
No worries thanks!
xcelr8 is offline
post #7 of 11 (permalink) Old 03-03-2019, 10:17 PM
He has the slotted pushrod guide holes in the head and by the amount of the valve tip sticking above the valve/spring retainer indicates these heads are change level 10. Non-rail rockers are needed in this case. A word of caution here. Unless everything is 100% stock in the valve train (Did you change the cam?), be sure to check the pushrod length.
I'm not sure what you are seeing in terms of prices for the OE style rockers but I just checked NPD and they cost $24 a piece. Holy crap! You may want to consider the Comp Cams roller tip rockers (1442-16) as an option. I put these on my 289 with low profile valve covers and have been happy. No problems so far. A complete set (16) with ball and nut at Summit is $161.
https://www.summitracing.com/parts/cca-1442-16
markb0729 is offline
post #8 of 11 (permalink) Old 03-04-2019, 07:53 AM
I have many of these rocker arm, if you still need them.
rose62 likes this.
Thanks,
Craig
Email: [email protected]
Phone: 603.673.6473
Web: http://www.neperformancemustang.com
NEPM is offline
post #9 of 11 (permalink) Old 03-04-2019, 10:48 AM Thread Starter
xcelr8's Avatar
Only modification I've made is Comp Cams High Energy cam which the rep at SEMA said could be used with stock rockers and pushrods. I'm also using their matching valve springs.
Yeah, $24 ea.... take a hike. Not sure what everyone is making these things from but I need to get in on it.
Do still need and would appreciate any you can part with.
xcelr8 is offline
post #10 of 11 (permalink) Old 03-04-2019, 11:37 AM
Something changed so I would check anyway. You can buy a pushrod length checker at summit and check for the correct length when putting the engine back together. Cheap insurance that the rebuild is done right. Decking the block or milling the heads also count as a change.
The reason I’m stressing this is that my 289 was rebuilt by a so called “Ford Expert”. The cam installed was closer to stock than yours. The block was decked and heads milled. Everything except the cam was stock. To make a long story short the rockers were riding towards the edge of the valve tip. One of the rockers would ride off the valve tip and contact the spring retainer. This caused the rocker to tilt and dig into the rocker stud. Good thing I caught this in time before I dropped a valve or sheered off the rocker stud. After I redid the heads and reinstalled them, I checked the pushrod length and stock pushrods were too long. I installed the correct length pushrods and all is well.
post #11 of 11 (permalink) Old 03-04-2019, 11:40 AM Thread Starter
xcelr8's Avatar
Great information, thanks for the heads up
xcelr8 is offline
Similar Threads
No oil to rocker arms Manassas66 Vintage Mustang Forum 14 01-26-2019 09:53 AM
Borderline stock but reliable 289 build....hit a wall. xcelr8 Vintage Mustang Forum 16 01-16-2019 08:50 AM
How to do the boss 289 rocker arm conversion geicoman58 Vintage Mustang Forum 23 07-07-2018 10:44 AM
302 rocker armstud question vs 289 kml1966 Vintage Mustang Forum 9 03-13-2018 03:38 PM
1965 Mustang 6 cyl - no oil to rocker arms Albinoewok Vintage Mustang Forum 6 11-26-2017 10:14 AM
