Bought this car as a donor car for my 67 fastback. - Vintage Mustang Forums
post #1 of 2 (permalink) Old 10-16-2018, 07:21 PM Thread Starter
Need some help. I need to order a power steering delete pulley for it. Question is which one do I need to order? It's a 1988. Right now as is the previous owner has removed the power steering pump, and has water pump turning backwards.
post #2 of 2 (permalink) Old 10-30-2018, 10:04 PM
if you aren't going to run a power steering pump or an ac one you can get a bracket and run a standard rotation pump that will go around just your alt, crank, and waterpump. that's the setup I use in two of my cars and it works like a charm.
foxbody mustangs came with a reverse rotation water pump that turns counter clockwise.
if I remember correctly part number wp-641 at advanced auto or autozone is a standard rotation pump the will rotate clockwise. it is from a crown vic.
if you can post a pic of your pulley setup it might help figure out what you have going on.
adumb is offline
