Frankenstein car high idle issue - Vintage Mustang Forums
post #1 of 4 (permalink) Old 02-27-2019, 06:12 PM Thread Starter
Hey everyone. So I have a 66 mustang that I put a 94' SN95 motor in. I am however using a DA1 (87 federal emissions) computer to run it on speed density. Now everything thus far is working except that I have a high idle. Now I have not been able to take the car out for a road test to see if the computer "learns" and adjusts the idle, so everything I have done is just running it in the driveway. KOEO I do not get any related codes. I get a few for emissions but I dont have them installed. KOER I just get the code telling me I have a high idle. I have set the base idle speed to 750 rpms and it will run like that all day until I plug the IAC valve back in and it takes over shooting the RPMS up to 1200. I am using the 94' TPS sensor, but with the throttle plate closed it is reading .95 volts. I originally had an IAC from a 87 speed density car thinking that the computer would be happiest with a same year sensor, but idle was high so I changed it out with a new one from the parts store, same thing. I took one out of a known working car, same thing high idle. So I tried a IAC from a 94 to match the motor and it ony made the difference in that my idle rpms would fluctuate like the computer was searching for the correct idle, whereas before they were stable but high. the fluctuation would be from 1200-1400 rpms. Same story, if unplugged it the RPM's would drop to 750. I have cleared the computer KAM each time and then letting the car idle for about 20 minutes for the computer to relearn the idle. Im at a bit of a loss of what to try next. I have checked and rechecked for vacuum leaks. Any ideas?
OldManJenkins is offline
post #2 of 4 (permalink) Old 02-27-2019, 07:35 PM
Just some guy
GypsyR's Avatar
A faulty engine coolant sensor/connection can tell the the PCM it's cold all the time and the PCM will jack the idle up. Do you have some way to view live data or just codes?
GypsyR is offline
post #3 of 4 (permalink) Old 02-28-2019, 02:10 PM Thread Starter
No unfortunately I’m using the paper clip method. I tested my ECT sensor. I have 4.7 volts at the plug and around 39.3 Kohm at 65.8 and 5.2 Kohm at 157. So it’s in spec for both cold and hot temperatures.
post #4 of 4 (permalink) Old 02-28-2019, 07:24 PM
Just some guy
GypsyR's Avatar
It gets tricky without a datastream. Basically the computer is seeing some reason to tell the IAC to raise the idle. Next most common culprit I guess would be the TPS. Pretty easy to check one with a multimeter.
GypsyR is offline
Similar Threads
Congrats Calamity Jane - Nice WSJ article Garth66 Vintage Mustang Forum 62 10-06-2018 10:44 AM
Rebuilt carb, now it won't idle 19Fastback65 Vintage Mustang Forum 44 09-30-2018 08:27 PM
66 Mustang Hardtop 289 CA. car project 289kman 1964 1/2 through 1966 Mustangs For Sale 0 08-31-2018 01:16 PM
Our First Weekend Together JonnybravoM3 Vintage Mustang Forum 6 01-19-2018 10:57 AM
High mileage F150 - oil pressure issue Kelly_H General Discussion (Non-Vintage Mustang) 10 12-24-2017 09:21 PM
