Good brand for engine stand for a fully loaded 351C? - Vintage Mustang Forums
 3Likes
post #1 of 25 (permalink) Old 09-14-2016, 06:32 AM Thread Starter
russosborne's Avatar
I'm getting crazy thoughts that I need to pull the engine from my 72 Ranchero and seal it up, as it leaks pretty bad and the car is down anyways needing the front suspension reinstalled(new soft parts) and the floor pans need replaced (waiting for money to buy a mig welder and gas, going to be using 65-70 full length Mustang pans, not a perfect match but they do work). I am also waiting a bit on the heat here to finally go away. I am too old to do this stuff in the summer here unless it is an emergency anymore. I got the front suspension off the car in April I think it was, but the heat got to me by the time I got all the parts here.
I have a hoist already but no stand. If I didn't have the hoist I wouldn't be thinking crazy thoughts like this.
Of course budget is always an issue, and the prices have skyrocketed on this stuff in the 8 or more years since I really bought anything like this new. Not at all opposed to used, but HF seems to be the most popular one for sale there. I can deal with an HF one if it will safely hold the engine.
Thanks,
Russ
RIP Mallory, Abby, and Sadie. And now Casey. :-( We miss you girls.
79 Pinto Hatchback. Fully caged, 8inch 4:10 gears. 351W. Aftermarket Tremec T5 (1352 251), Going to be a fun cruiser.
74 Pinto Wagon.
On maybe permanent hold.
72 Ranchero GT w/351Cleveland & automatic. Although this wasn't supposed to be a project car it seems that it has become one. Stupid rusted out California floor pans.
russosborne is offline
post #2 of 25 (permalink) Old 09-14-2016, 06:50 AM
Runnin' Back to Saskatoon
4ocious's Avatar
I have one of the Harbor Freight stands and it works for me just fine, 750 lb. capacity, and my engine weighs 498 lbs. (91' 302 roller all dressed up and ready to install).
'68 302 T5z Custom Conversion.
4ocious is offline
post #3 of 25 (permalink) Old 09-14-2016, 06:54 AM
sportsroof69's Avatar
The AC Delco they sell at Oreilly is pretty good.
sportsroof69 is offline
post #4 of 25 (permalink) Old 09-14-2016, 07:53 AM
fordguy's Avatar
I have a larin 4 leg 1000lb stand. it's held everything from small blocks to big blocks with no problems
66 mustang coupe, 302 / T5-Z / 3.80 trac-lok
fordguy is offline
post #5 of 25 (permalink) Old 09-14-2016, 09:03 AM
j persons's Avatar
I have the basic 3 leg stand that was given to me as payment for some work I did back in 1987. I think it was originally from HF and has held everything from a 454 long block to a 302 small block. It would be nice to have one with the geared head that makes rotating a snap, but for the money the HF stand is hard to beat.
F-150 SCab daily driver
j persons is offline
post #6 of 25 (permalink) Old 09-14-2016, 09:05 AM
I have the larger HF (1000lb) 4 leg stand. It held my fully dressed 351W for months with no problem.
patrickstapler is offline
post #7 of 25 (permalink) Old 09-14-2016, 09:44 AM
PetesPonies
Posts: n/a
Basically, any of the stands will work. If you have a welder, then welding some of the connections will make it bullet proof.
silverblueBP likes this.
post #8 of 25 (permalink) Old 09-14-2016, 09:50 AM
fordguy's Avatar
i'd buy a 4 leg regardless of what brand you buy. I personally don't like the 3 leggers, they are easy to tip when you're moving them loaded.
fordguy is offline
post #9 of 25 (permalink) Old 09-14-2016, 10:25 AM
If you don't need to flip it over, then you can use some 2x10's and a furniture dolly. It limits access to the bottom part of the motor, but for cheap storage, it's hard to beat.
This is the 302 that will go into my fastback.
Here's one a made for a 354 Hemi for my last project.
Dan
Chapel Hill, NC
***PM me if you're close by and can lend a hand with my 65 Fastback project***
Dan Babb is offline
post #10 of 25 (permalink) Old 09-14-2016, 10:52 AM
silverblueBP's Avatar
I bought a cheap one from summit and added casters. Works great! 4 leg, 1" square tubing.
-Mark-
1966 Mustang 2+2
silverblueBP is offline
post #11 of 25 (permalink) Old 09-14-2016, 11:53 AM
Yes ! My 289 took a tumble on a 3-leg stand when the front wheel hit an obstruction.
'65 A-code coupe, T-10 4-speed, 8" 3.25 limited slip
stephen_wilson is offline
post #12 of 25 (permalink) Old 09-14-2016, 01:51 PM
Just some guy
GypsyR's Avatar
I don't worry too much about brand. At the lower price scale I'm pretty sure they all come from China anyway.
This type I refuse to use as I hate when 600 pound engines fall on me.
This is what I use. The narrower legs help you get into the vee of most engne hoists. Somewhat at least. You can still tip one over if you try hard enough. I've seen two go over. One trying to free a seized engine and the other when angle torquing head bolts. I like mine anyway, I'm careful about certain actions with it.
The last is very stable but I find them a bit inconvenient when transferring engine to and from a typical cherry picker engine hoist. If you use a chainfall instead you don't care about that. They to be obnoxiously in the way when you aren't using them. One definitely sucks up more floor space than the other to.
I've no interest in using a 750lb. 1000 is the minimum for me. A 300 six isn't terribly heavy but it is very long. Put one on a 750lb stand and it will bounce like it's on a bungee. Very disconcerting. Since that one I've been rather sensitive to bounce. Also I had an engine (big block? I forget) on a 750lb stand that made the stand sag down to where I couldn't rotate the engine over. You don't have have a 1000 pounder but I for one WILL pay more money for that extra feeling of stability.
I would have no issue buying one from Harbor Freight. Mine came from an auto parts store's promotional sale.
GypsyR is offline
post #13 of 25 (permalink) Old 09-14-2016, 02:05 PM
Just some guy
GypsyR's Avatar
"Fully loaded" 351W. Out of the 15 or so years I've had this stand I bet there was only about two weeks total where there was no engine on it.
Many 1990's larger FWD GM's had Monte Carlo type bars which apparently the junkyards remove when they pull the engines. I collected about six of those for ten bucks or so, bought some casters, and welded up a little roll around stand for another engine. THis was when you them available everywhere for Chevys for like $35 but none for Fords. Never took a picture but I patterned it after the commercial ones.
GypsyR is offline
post #14 of 25 (permalink) Old 09-14-2016, 02:34 PM
fordguy's Avatar
I agree 100%. I have three stands, two of the four leggers and one of these wide four leggers. it's disassembled and tucked away under my bench. like you said, it's a pain in the arse trying to use a hoist with it.
fordguy is offline
post #15 of 25 (permalink) Old 09-14-2016, 05:35 PM
PetesPonies
Posts: n/a
It's called "natural selection"
If you get a good deal, makes no difference what you buy. They all work and can be modified easily if you wish.
