Shower Plumbing help? - Vintage Mustang Forums
 6Likes
post #1 of 21 (permalink) Old 04-05-2018, 12:14 AM Thread Starter
Are the new shower manifolds (where the hot/cold water is mixed and turn handles to get it out) some kind of low flow stuff? I replaced the old manifold when I put in a new tub, the new "Caulk-less snap together type unit". The flow is just ridiculously slower than before. Of course the spousal unit complains that she can barely get the shampoo out of her hair. Red heads get really ill about such things....well most things anyway...lol I've gotten weary with her whining on this. How do I rectify this situation and get more water flow?
Thanks for any help.
gwstang is offline
post #2 of 21 (permalink) Old 04-05-2018, 02:33 AM
C6ZZGT's Avatar
Good luck in this age of reduce reuse recycle,low flow/water saving plumbing is the standard ,fire hose pressure/volume plumbing is out of vogue.
6r07a143871 --owned since 10/83
C6ZZGT is offline
post #3 of 21 (permalink) Old 04-05-2018, 02:33 AM
maladezo's Avatar
If it is restricted, there is probably a removable restriction piece.
'67 coupe, 390, 4spd.
maladezo is offline
post #4 of 21 (permalink) Old 04-05-2018, 06:44 AM
droptop119's Avatar
Did you replace the shower head? If so,the restriction is most likely there. All new ones come with restrictors installed to save water. This is usually easy to remove. Just unscrew the shower head & look in the end where the threads are. There is a small rubber piece ( washer type) in there. I use a long drywall screw to remove it. This is your water restrictor & if removed will make your shower feel like normal once again.
gwstang likes this.
1968 GT VERT ROYAL MAROON J CODE
OWNED FOR 45 years
droptop119 is offline
post #5 of 21 (permalink) Old 04-05-2018, 08:03 AM
Magnus's Avatar
My shower valve had a plastic ring on it so it could only turn so far. Once I took the handle off and started poking around it was pretty obvious that's what was causing the problem. I wouldn't be surprised if yours has something similar keeping you from turning the handle all the way to 'full'.
They really should mention this sort of thing on the box or that little rice paper thin multilingual instruction insert so you know how to fix it before you get it installed, but maybe that's just me.
gwstang likes this.
Magnus is offline
post #6 of 21 (permalink) Old 04-05-2018, 09:32 AM
awhtx's Avatar
Believe it or not I know of a guy who uses a garden hose hanging over a tree limb as a shower. I bet that's fun in the winter!
awhtx is offline
post #7 of 21 (permalink) Old 04-05-2018, 09:46 AM
When i had my inground pool i would get a five gallon bucket of water from the pool and set it in the sun to warm up and take a pool water shower after a hard days work by using the five gallons to lather up and pour the rest over my head and then jump in the pool without taking all my sweat and dirt in the pool, hardly ever had to put water in the pool as in florida in the summer we get an afternnon shower. A great way to get refreshed for free! Wes
mustang656man is offline
post #8 of 21 (permalink) Old 04-05-2018, 08:06 PM Thread Starter
Thanks guys, I'll take a look inside the shower head (hand held water pik new unit).
gwstang is offline
post #9 of 21 (permalink) Old 04-05-2018, 08:58 PM
What brand of control is it? They are all low flow now, but some have adjustment built into them that will let you "turn it to 11" a little. The cheaper ones tend not to have any adjustment, but are generally easier to modify. Let me know what brand it is and I've got a buddy (a real plumber) that I can ask. Then there's the shower head itself. It sounds like you're on that already though.
jgrote is offline
post #10 of 21 (permalink) Old 04-05-2018, 09:03 PM
Nailbender's Avatar
The newer units are on to that, drill bit is required on the better units these days. The internet is your friend.
65 C Code hardtop from California still wearing it's original paint.
Roller 331, TW 170 heads, T-5z, FiTech EFI, FPA Headers, Arvinode exhaust, SoT Bilstien coilover front suspension, TJ on eBay 8" 3.40 Trac-Loc 3rd member. Mustang Steve 2008 GT bracketed 12.4" front disks
Nailbender is offline
post #11 of 21 (permalink) Old 04-05-2018, 09:13 PM
subpar63's Avatar
You need to hook up with this guy and get the Commando 450
John Goettsch
My First Mustang
Z-Member - Arvinode Exhaust
66 FB C Code C4
White/Aqua Pony Interior
subpar63 is offline
post #12 of 21 (permalink) Old 04-05-2018, 09:30 PM
jgrote is offline
post #13 of 21 (permalink) Old 04-05-2018, 10:35 PM Thread Starter
Ahh Sooo! There was a little blue disc when I unscrewed the shower head. Like it was said, a screw in it and snatched it right out. It will knock her down now...maybe she will get off my arse now....or maybe not....lol Thanks everyone.
gwstang is offline
post #14 of 21 (permalink) Old 04-05-2018, 10:42 PM
The thing is, now that you've fixed this, she'll find something else for you to fix!
jgrote is offline
post #15 of 21 (permalink) Old 04-06-2018, 09:07 AM
Living here in California, low flow is mandatory. I'm sure a person would get jail time for messing with the shower head. A few years ago the bride and I took a cross country car trip. The hotel where we stayed in Memphis had a shower that would peel skin. One of the highlights of the trip.
deltadude is offline
