1966 mustang AJE k member help - Page 2 - Vintage Mustang Forums
 1Likes
post #16 of 34 (permalink) Old 04-28-2018, 02:56 PM
Harryburroughs is offline
post #17 of 34 (permalink) Old 05-15-2018, 04:27 PM
Would Fox body coilovers be optimal over sn95 coilovers if you didnít have either to start? Thanks
Nmkv8pwr is offline
post #18 of 34 (permalink) Old 05-16-2018, 10:30 AM
for a lowered car foxbody
strtcar is offline
post #19 of 34 (permalink) Old 05-26-2018, 05:32 PM
Blue Blood's Avatar
Send a message via MSN to Blue Blood
I'm usually fairly good when searching the net, but in this case I'm challenged to find Fox body, front coilover struts that include the bracket that mounts to the spindle. Any info regarding this would be greatly appreciated.
Thanks, Clint
1995 GT Convertible - Laser Red - 331 stroker, Kenne Bell 2.2 - 415 RWHP 396 RWTQ
2002 Corvette Z06 - 410 RWHP 410 RWTQ
1968 Mustang Fastback .... Rustbucket slowly being reborn
Blue Blood is offline
post #20 of 34 (permalink) Old 05-26-2018, 06:17 PM
j persons's Avatar
Thanks, Clint
Check with Maximum Motorsports. I used to have a Fox body that used their Koni coilover kit. Coil-Over Package, MM Dampers, 1979-1989 Mustang
F-150 SCab daily driver
j persons is offline
post #21 of 34 (permalink) Old 05-27-2018, 12:36 AM
Blue Blood's Avatar
Thanks, I found stuff, just gotta put everything together.
post #22 of 34 (permalink) Old 09-25-2018, 12:29 AM
Blue Blood's Avatar
For the guys that donít have the adjustable lower control arm, how did you align the front end?
Thinking about swapping to the adjustable arms, will they fit to the same K member?
post #23 of 34 (permalink) Old 09-25-2018, 08:42 AM
Huntingky's Avatar
My Griggs LCA has no adjustment. Cast and camber adjusted on UCA.
Coyote build in 65 GT Fastback in body work https://forums.vintage-mustang.com/b...e-powered.html and on Facebook @65gtmustang
F150 SCREW Ecoboost as my daily
66 Emberglow Coupe first car,71 Torino GT, 82 Fastback slooooow 6 banger, 71 Boss 351, 85 GT all long gone
Huntingky is offline
post #24 of 34 (permalink) Old 09-25-2018, 11:59 PM
Blue Blood's Avatar
d
That leave toe-in and toe-out, how do you address that?
post #25 of 34 (permalink) Old 09-26-2018, 08:27 AM
Huntingky's Avatar
d
Tie rod ends
post #26 of 34 (permalink) Old 11-13-2018, 11:31 PM
BinaryEditor's Avatar
I cant speak towards the 65-66 but i have the AJE on my 67 and yes you can install the sway bar. I cut the shock towers back to give me room for the FE motor. I used the AJE lower control arms and I used the 95 spindles for the bigger brakes. I also had to get different coil over shocks and springs rating for the big block. The cartridge that is in the strut is a Toyota MR2. It is very stiff. I replaced them with the koni adjustable which are much better shocks. alignment was able to be brought into spec without any issues.
Brakes were a little different to configure because of the different line sizes but it is all doable. Biggest issue i had was with the steering. The 67 in mid year came with a rag joint and mine was early model and had a solid shaft. I cut the end off and it had spines on it. I then talked with AJE and they sent me the updated steering knuckle.
I have a bunch of pictures in the link in my signature. Here is one when I was mocking it all up.
BinaryEditor is offline
post #27 of 34 (permalink) Old 11-13-2018, 11:32 PM
You will need the bump steer kits to correct for the angles. You can also get a offset bushing set for the rack and pinion. Cast and camber adjustments are done on the op by rotating the top mount on the strut.
post #28 of 34 (permalink) Old 11-14-2018, 12:17 PM
sorry for the multiple post. Trying to lean how to attach pictures on this forum
post #29 of 34 (permalink) Old 08-10-2019, 05:42 PM
I'm doing the same on my 66 convertible. Got the AJE K member and A arms. Tried using fox boxy struts with UPR coil over kit, including fox body camber plates.
The camber plates won't work, difficult to mount and not enough adjustment (camber).
Anyone know if the top of fox body struts will mate with the AJE camber plates from their AJE-6470 kit IF they even sell the plates separately?
Like other posters, the 6470 seems over priced.
onetrkpny is offline
post #30 of 34 (permalink) Old 08-10-2019, 05:45 PM
Anyone know if those CC plates can be bought separately and will it fit foxbody struts?
