Crushed Frame Rails - Vintage Mustang Forums
 4Likes
  • 1 Post By Ferganzer
  • 2 Post By DrStang
  • 1 Post By Caper50
post #1 of 10 (permalink) Old 07-18-2018, 10:07 PM Thread Starter
Ferganzer's Avatar
Crushed Frame Rails
Hello All,
I need some advice on my frame rails. I bought this 66 about a half a year ago and the previous owner seemed to like to go off-roading in it as the frame rails on the front are a bit crushed in on the bottom. I am installing frame connectors and need them to be flat so I can secure them to the frame rail. What would you recommend to do to “square up” the frames?
Ferganzer is offline
post #2 of 10 (permalink) Old 07-18-2018, 10:19 PM Thread Starter
Ferganzer's Avatar
To add to my question,
The frame rails on the front aren’t that badly crushed in, they just are not perfectly flat. The car is in awesome shape just some slightly crushed in frames. Any advice would be great! Thanks
post #3 of 10 (permalink) Old 07-18-2018, 11:09 PM
I have the same problem and haven’tt fixed mine yet. .
Some cut off a portion of the frame rails, straighten them, and weld them back on.
Others cut back the floor to get to the inside of the frame rail and them weld the floor back up
Other drill out the spot spot welds to completely remove the frame rail extensions and then repair or replace.
James
66 Coupe Project 289
Eitelbj is offline
post #4 of 10 (permalink) Old 07-18-2018, 11:30 PM Thread Starter
Ferganzer's Avatar
Eitelbj
Yeah that’s what I was thinking. I think I solved the problem. I am going to weld some angle iron on the frame rails to make it square as well as add some strength. I think it will work good as long as I can get the angle iron welded on properly and securely.
Thank you!
Eitelbj likes this.
post #5 of 10 (permalink) Old 07-19-2018, 04:07 PM
DrStang's Avatar
Using a bottle jack etc... are common reasons for those depressions.
Mine had those indents, and I'm the one who put them there. But it was 1983 and I was young and dumb. Now just older and less dumb
gt350sr and 67Modcoupe like this.
"A good friend will help you move. A great friend will help you move a dead body"
September 2017 Mustang Monthly cover car
1965 A-Code Fastback
Built, September 14, 1964 (San Jose)
Viper red, White/red interior
TCP R&P, G Bar rear 4 link/w shockwaves
Global West Upper/Lower/Strut Rods
Ride-Tech Air ride
4 wheel Cobra disc brakes/Hydroboost
363 Stroker/Paxton Supercharger
Mass-Flo EFI
Owned since 1983
DrStang is offline
post #6 of 10 (permalink) Old 07-19-2018, 04:45 PM
gt350sr's Avatar
Originally Posted by Ferganzer View Post
Hello All,
Did it happen to have 'Mulestang' or Gambler decals on it??
Working on old cars teaches us patience... and every curse word imaginable!
gt350sr is offline
post #7 of 10 (permalink) Old 07-19-2018, 05:59 PM
Caper50's Avatar
I'm assuming you are talking about the bottom of the floor supports as opposed to the front frame rails? Post some pics of the areas in question.
image98 likes this.
Caper50 is offline
post #8 of 10 (permalink) Old 07-19-2018, 07:09 PM
LeeFred's Avatar
Most likely the OP is talking about the floor supports. Quite a few of us used those as jacking points over the years and lived to regret it. Mine are the same way - looks like I've been off roading a few times. One of these days I'll have to get them repaired/replaced.
LeeFred is online now
post #9 of 10 (permalink) Old 07-21-2018, 12:10 AM Thread Starter
Ferganzer's Avatar
Yeah I was talking about the floor supports. They aren’t that bad, just allowing for a bad Purchase area for frame connectors. Got it figured out by welding a peice of angle across it to strengthen and square it up. And hold the frame connectors. Thanks for the help!
post #10 of 10 (permalink) Old 07-24-2018, 06:48 PM
Rudedog289's Avatar
Mine are dented up too, but they are straight. I didn't worry about it. I did weld in Global West tubular subframe connectors. They make excellent jack points themselves especially toward the center where I can lift the whole side of the car up with my super high speed racing floor jack (aluminum no less) from Harbor Freight. If you are worried about the dents then take thicker flat sheet metal (1/8 to 3/16), cut to shape and weld that in to hide the dents. Oh dents add character!
66 T code Coupe converted to 289 V8
T5Z, Explorer 8.8 w/3.73 LS,
Replaced a lot of sheet metal & too much other stuff to list
DOL
Rudedog289 is offline
