DIY Fan Controller - Vintage Mustang Forums
 1Likes
post #1 of 22 (permalink) Old 03-01-2019, 09:20 PM Thread Starter
DIY Fan Controller
Ok giving back! I used this PWM controller on my Taurus two speed fan. I just hooked it up to the high speed side. Newer cars a re coming out with brush less motors so I'm looking to replace the motor on my fan with one, if anybody knows what may fit let me know!
https://ls1tech.com/forums/forced-in...-less-diy.html
1 3/4 UCA drop, Roller Spring Perch, Diy struts, roller boxed LCA, Power brakes,70 front disk, 8.8 Rear-end 3:25, T-5 hydraulic clutch, Alum Rad with Taurus Fans.
Triton is offline
post #2 of 22 (permalink) Old 03-03-2019, 01:07 PM
The C7 Corvette uses brushless fan. It is sized about right for older cars. It is rated at 600watts.
Andrew
My YouTube Channel. Please subscribe.
Instagram @projectgattago
andrewb70 is offline
post #3 of 22 (permalink) Old 03-03-2019, 08:02 PM
I will be using the below for my 347 build with Champion 3 core 24" radiator and Ford Contour dual fan
Auto Cool 85 PWM controller from https://www.autocoolguy.com/
For $175 it's worth it to me because I'm using the new Edelbrock ProFlo4 which has no provision to control fan.
J
jsulse is offline
post #4 of 22 (permalink) Old 03-07-2019, 10:44 PM
J
J,
I have installed one of those AutoCool boxes and I was not impressed. They are HUGE and tend to "buzz." I suggest the Fk75
DC Controls
Andrew
post #5 of 22 (permalink) Old 03-09-2019, 01:13 AM
Thanks for the heads up Andrew. I will look into the DC Controls unit.
andrewb70 likes this.
jsulse is offline
post #6 of 22 (permalink) Old 07-12-2019, 01:27 PM
66coupe289's Avatar
So one of the things I have in my new old stock collection that is a 12 year old Spal PWM fan controller. I see those are discontinued and reviews seem poor. I currently control the fan with the temp sensing switch and relay. Should I just sell the Spal PWM and stick with what I have, or go to another controller?
I am running a single Spal fan, again 10+ years old.
Chris (Sussex, WI)
289 w/AFR 165, T-5z, 3.55T-loc, Granada Discs and 6 bolt Moto-Lita Steering Wheel
66coupe289 is offline
post #7 of 22 (permalink) Old 07-12-2019, 03:32 PM
wicked93gs's Avatar
Can always do it old school and simple...older Porsches have a simple temperature switch that screws into the radiator and opens a relay to turn on the fan...you can add a bung to an aluminum radiator to fit this switch...or alternatively add a bung to a water pipe or t-stat housing to the same effect(might even be able to simply tap the correct thread if you have someplace with enough metal) The Porsche switch is like $9.99 from any auto parts store...add in another $10 for a relay and wiring and voila...no crazy controller needed.
wicked93gs is online now
post #8 of 22 (permalink) Old 07-12-2019, 05:15 PM
Location: Granite Bay, California, 5 minutes from Folsom Lake
Originally Posted by Triton View Post
Ok giving back! I used this PWM controller on my Taurus two speed fan. I just hooked it up to the high speed side. Newer cars a re coming out with brush less motors so I'm looking to replace the motor on my fan with one, if anybody knows what may fit let me know!l[/url]
I got two Spal high volume brushless fans in a custom built shroud that spaces the fans off the radiator so that they pull air from farther corners than just two small 'donuts' when the fan is right up against the fins. The Spal brushless have a built-in waterproof variable speed controller and you just change the sensors if you want a different heat range. They work like this (see sensor list at the bottom of the link): the 185 degree sensor first turns on the fans at 25% at 165 degrees, then variably increases the fan speed until it hits 100% at 185 degrees. See below. Several size fans available and 3 diff sensors.
Spal Brushless fans at Wizard cooling
Fishfreq is offline
post #9 of 22 (permalink) Old 07-17-2019, 11:46 AM
Spal offers the mating connectors for those brushless fans.
Andrew
post #10 of 22 (permalink) Old 07-18-2019, 12:06 AM
russosborne's Avatar
Could you please tell me what years would have these?
Russ
RIP Mallory, Abby, and Sadie. And now Casey. :-( We miss you girls.
79 Pinto Hatchback. Fully caged, 8inch 4:10 gears. 351W. Aftermarket Tremec T5 (1352 251), Going to be a fun cruiser.
74 Pinto Wagon.
On maybe permanent hold.
72 Ranchero GT w/351Cleveland & automatic. Although this wasn't supposed to be a project car it seems that it has become one. Stupid rusted out California floor pans.
russosborne is offline
post #11 of 22 (permalink) Old 07-18-2019, 01:14 AM
wicked93gs's Avatar
https://www.ecstuning.com/b-wahler-p...yABEgI0ePD_BwE
Honestly I cant remember the full year range, but here is one for 92 degrees Celsius(197 degrees Fahrenheit). You can find them in varying prices and I believe varying temps all over the web...I used the 197 myself in one of my builds without issue..but was a newer engine...I might try to find a 180 for an older pre-cat engine
https://www.pelicanparts.com/More_In...yABEgIUKfD_BwE
Here is a 185, but I never used one of the 3 blade switches, so wiring may(or maybe not) require something extra
post #12 of 22 (permalink) Old 07-18-2019, 10:14 AM
Just some guy
GypsyR's Avatar
I suspect the price varies on those according to how aware people are that they are the exact same ones as used on 1979-84 VW Rabbits and stuff. Stick "Porsche" on them and no doubt people will pay extra. Either way I wouldn't have a problem using one. But what do you screw it into? I have a vehicle that uses one of those OEM, it screws into a bung in the radiator. My Fords are sporting no such bungs. I have a hose Tee that would accept such a sender from a Saab, but it fits a hose somewhere in between heater hose size and radiator hose size and so is pretty useless.
GypsyR is online now
post #13 of 22 (permalink) Old 07-18-2019, 11:27 AM
wicked93gs's Avatar
You can easily weld a bung of the correct size into a t-pipe....or possibly find some stock application in-hose pipe of the right size for it with a little searching...or if you have a TIG and an aluminum radiator weld a bung in there....copper/brass radiators I have moved outlets from one side to another with brazing before as well, so that's also a possibility, but in the end...I am sure a lot of different manufacturers have some type of temperature switch...this is just the one I know of offhand and have used before on other cars I have built
post #14 of 22 (permalink) Old 07-18-2019, 02:16 PM
Just some guy
GypsyR's Avatar
Just curious how YOU used these. I've had an eye out for a piece of OEM pipe that accepts one or another of these style senders for like 15 years with no luck. That's how I ended up with the Saab piece. I know there are a couple of members here who can and will TIG something into aluminum but I believe I'm in the vast majority of those here who have no such DIY capability or ability.
So basically I was kind of hoping you'd say something like we can simply pop over to McMaster-Carr or something and buy part number XX4XX and install into X.X size radiator hose. No such luck? Any pointers on where to source the (steel) bungs then?
post #15 of 22 (permalink) Old 07-18-2019, 02:25 PM
wicked93gs's Avatar
Last I used one was on a 1977 Toyota Celica....I had a radiator shop braze a bronze block to the radiator end tank...then simply tapped it to the correct thread.
As for a bung...for that particular size, you have the easy option of a spindle nut:
https://www.pirate4x4.com/forum/atta...tch-.jpg?stc=1
P.S. I love the Pirate 4x4 site...there is so much obscure automotive knowledge on that site.
Similar Threads
New electric fan controller macstang Vintage Mustang Forum 6 02-02-2019 05:55 PM
Thinking of ditching my electric fan - talk me out of it mike306 Vintage Mustang Forum 23 06-12-2018 05:25 PM
Fan - Front versus Rear 1968Cally Vintage Mustang Forum 2 04-17-2018 12:52 PM
Suggestions for an electric fan controller? 1968Cally Vintage Mustang Forum 44 03-12-2018 09:56 PM
