Thoughts on using a Miata IRS cradle? - Vintage Mustang Forums
 8Likes
post #1 of 23 (permalink) Old 05-08-2019, 10:51 AM Thread Starter
wicked93gs's Avatar
Its been forever since I posted on here(sold my one project car, but about to buy another 66 coupe next week). Anyway, in the time since I sold my last mustang I bought a 91 Miata I drove for a few months...and they of course handle extremely well...but more importantly the whole IRS system is based on a cradle that bolts to the chassis with 4 bolts...the control arms(upper and lower), carrier, etc. Obviously the miata carrier isn't sufficient for a torquey v8 or even a built inline 6, but the cradles are easily modified to hold a Ford 8.8 IRS from a T-bird or Explorer, or Cobra(I actually have a Ford 8.8 mounted to a spare miata rear cradle right now). With the Miata track width being 56.2" and the 65-66 Mustang being 56" it makes it a very appealing option. Miata hubs can be swapped for T-bird/Cobra hubs with minimal modification(though the 5 lug bolt pattern on the T-bird hubs needs to be redrilled to 5x4.5, whereas the far more expensive Cobra hubs already have the right pattern).
The only real problem I see(aside from cutting down an re-splining whatever CV axles best fits the carrier/hub combo you choose(Moser does this for a little over $100 an axle if I remember correctly)) is the physical fitment of the cradle in a mustang chassis(mostly shock mounting and whether the thing will fit in the space meant for a solid axle). Anyway, purely theoretical discussion...practical option? maybe with a shorter strut assembly?
wicked93gs is offline
post #2 of 23 (permalink) Old 05-08-2019, 12:46 PM
Sounds completely doable. You'd need to strengthen the floor structure and tie that into the upper strut attachment. You'll probably lose some of the back seat, but that would be neat!
gus91326 is offline
post #3 of 23 (permalink) Old 05-08-2019, 01:47 PM
rpm
rpm's Avatar
I like the way you think wicked93!
Bob
There are 2 types of people, those who own pickups and those who borrow them.
69 M code Mach 1, 393w AFR 185, AOD trans, 3.50 traction lok N case, 13" 01Cobra 4 wheel disc, QA1 4 wheel coil covers, Chromo tube susp arms, Triangulated rear arms, Convertible inner rockers & seat riser, 8 point roll bar.
Build Pics http://s782.photobucket.com/user/rob...?sort=3&page=2
Build Thread
http://1969stang.com/forum/index.php...bitch-is-back/
rpm is offline
post #4 of 23 (permalink) Old 05-08-2019, 01:51 PM
Never heard of this one, so I'm not sure what the pitfalls might be, but it sure sounds cool.
post #5 of 23 (permalink) Old 05-08-2019, 01:51 PM
jdub's Avatar
With enough patience and fabrication skills I am sure you can figure it out. I'll be interested to see how it goes.
1965 Mustang
jdub is offline
post #6 of 23 (permalink) Old 05-08-2019, 05:49 PM
j persons's Avatar
probably would have cut out the spring pockets of a wrecked Miata to fab up some for the coilovers.
F-150 SCab daily driver
j persons is offline
post #7 of 23 (permalink) Old 05-09-2019, 11:25 AM
That would be an interesting exerciser. This might give you some hints and pointers of whats needed. https://dazecars.com/dazed/JaguarIRSSuccess.html
It seems the Miata would need mods to the mod as I guess they all would. Im not sure why the Jag rears were so famous in so many cars, maybe since it was one of the available IRS rear but these days there seems to be more cars to choose from, then again people that want such a thing can more readily buy an engineered kit off of a shelf. These kits may have stymied junk yard experimentation. Some rears I would want to rule out first are T-Birds and Lincoln Mark?s that had the IRS, as long as the springs would fit under the car I think you could make up the width differences at the wheels
Verbose Vocabularian
1ofAMillion+ is offline
post #8 of 23 (permalink) Old 05-09-2019, 12:01 PM
If you are going to keep it for a while I would consider doing it but its going to be LOTS of work, Lots of challenges along the way- but some people love that part of it!!
stealth 66 is offline
post #9 of 23 (permalink) Old 05-09-2019, 01:48 PM
RyanSterling966's Avatar
Send a message via AIM to RyanSterling966
Someone hand this man a beer please. This is a rad idea!
Huntingky likes this.
My Build thread:
http://forums.vintage-mustang.com/vi...thank-you.html
1966 Coupe I6 with australian head and a weber carb - Gone but not forgotten
2007 Mustang GT custom ordered - SOLD!!
1966 Fastback A-code - Finally Painted
2016 Shelby GT-350 Tech Pack Still like the 66 better
RyanSterling966 is offline
post #10 of 23 (permalink) Old 05-09-2019, 01:53 PM
Just some guy
GypsyR's Avatar
A few people kicked around a Tbird transplant here a few years back. I recall one standout difficulty with it was that the center section would protrude into the fuel tank's space. A lot. To the point you would just about have to do like Jaguar and fab up a pair of "saddle" tanks. Most folks lost interest at about that point.
GypsyR is offline
post #11 of 23 (permalink) Old 05-09-2019, 02:32 PM
Redneckgearhead's Avatar
A few years ago there was a guy that made the brackets to bolt in a cobra irs into these cars.
Daisy likes this.
Scott
Never let the truth get in the way of a good story
Redneckgearhead is offline
post #12 of 23 (permalink) Old 05-09-2019, 03:23 PM
give him a full box! Cool idea
Sveta is offline
post #13 of 23 (permalink) Old 05-10-2019, 11:37 AM Thread Starter
wicked93gs's Avatar
The Miata spring pockets are actually on the outside of the frame rail(see attachment I grabbed from GRM). Its hard to say whether you would be able to duplicate the setup on a vintage mustang. I would really need to measure the frame rail spacing on both cars to see where the upper shock mount would have to end up(I suspect the frame rail spacing is wider on the mustang by about 5-6" which would require mounting inside the frame rails and likely coilover shocks strictly for the smaller diameter spring) In any case, it is something I plan to look further into because it really doesn't seem to difficult...at worst it would require some floor cutting/reshaping for clearance and some new spring pockets/rear shock "towers" welded in, as well as some type of frame to hang the cradle...all pretty simple fabrication.
File Type: jpg Mazda_Miata_FCM_coilovers_with_special_MCU_bushings.jpg (649.8 KB, 2 views)
post #14 of 23 (permalink) Old 05-10-2019, 11:56 AM
Daisy's Avatar
I also vote for the mod kit that accepts the IRS from... a '99~ish Lincoln LSC (which had Cobra motor and IRS but can be found much cheaper...)
Daisy is a 1967 Coupe
Painted Frost Turquoise
Styled Steel Wheels
White Vinyl Roof
Deluxe Interior
WsW Tires
(And that big ol' 390 Engine )
Daisy is offline
post #15 of 23 (permalink) Old 05-10-2019, 12:05 PM
dobrostang's Avatar
The only way to answer the question is drop the springs and third member from a mustang in the air and see what happens when you roll the Miata rear in and try to fit. Its interesting as I was seeking a cheap posi for a TR3 I have with 4.1 gears and Miata center sections can be had relatively inexpensively. SO I have spent a lot of time staring at photos adn exploded views of Miata rears.
THe down side I believe would be resale, Who wants to include the word Miata in any Mustang discussion. Would I purchase a muscle car that had a third member mounted in a Miata frame? that would be pause for concern...
Great idea and thinking...
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
Similar Threads
Thoughts on Direction for Engine Project katwalk Vintage Mustang Forum 24 04-25-2019 12:07 PM
IRS, Anyone else? gwstang General Discussion (Non-Vintage Mustang) 21 01-28-2018 07:57 PM
