Lower Rad Hose for 65 with D/S water pump & outlet - Vintage Mustang Forums
 5Likes
  • 1 Post By Anangryford
  • 1 Post By Hemikiller
  • 1 Post By Lightning
  • 1 Post By Chaplin
  • 1 Post By Chaplin
post #1 of 13 (permalink) Old 06-10-2019, 01:56 PM Thread Starter
I am looking for a lower radiator hose to work with my standard 65-66 sized ACP Maxcore radiator with the outlet on the driver’s side and water pump also on the driver’s side.
I did a bunch of searching here and elsewhere and found no “direct fit” suggestions. I wound up modifying a Bronco upper hose and, while it fits ok, I’d like to find something better.
Anyone know of a lower hose that will work with set up without modification?
Chaplin is offline
post #2 of 13 (permalink) Old 06-10-2019, 02:30 PM
MrFlash's Avatar
I don’t know anything about your radiator but my 70 has a drivers side lower hose. Maybe that will work for you.
1970 Mustang coupe
MrFlash is offline
post #3 of 13 (permalink) Old 06-10-2019, 02:33 PM
Anangryford's Avatar
Can also try the foxbody lower.
Anangryford is offline
post #4 of 13 (permalink) Old 06-10-2019, 02:39 PM Thread Starter
Thanks. I did try a 70 hose and unfortunately it won’t work. The 70 has a wider rad than the 65 and the hoses don’t line up.
I can try a Fox, but I think the Fox rads are also wider.
Chaplin is offline
post #5 of 13 (permalink) Old 06-12-2019, 12:16 PM
It is wider. It could have been cut down except that the radiator side of the hose is too small in diameter. I will let you know what I find when I look around this week. I'm doing the same thing as you for a second time (first on my 67, and now on my 66) and I will be going through my old receipts and hanging out in the hose section of autozone soon.
Chaplin likes this.
post #6 of 13 (permalink) Old 06-12-2019, 12:40 PM
I'm using a '70 302 lower hose on my 65 with a drivers side water pump. Cut down the hose to fit and it works perfect.
65 coupe 5.0L/5 speed
2001 Lightning #1757
Lightning is offline
post #7 of 13 (permalink) Old 06-12-2019, 12:51 PM
Hemikiller's Avatar
Take a look at a 75 Maverick 302 lower hose.
https://www.rockauto.com/en/catalog/...ower+hose,2057
Chaplin likes this.
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
post #8 of 13 (permalink) Old 06-12-2019, 01:57 PM Thread Starter
Do you remember what brand hose you bought? I couldn’t make the 70 hose I bought (Napa) line up without creating a kink in it.
Chaplin is offline
post #9 of 13 (permalink) Old 06-12-2019, 03:04 PM
cmefly's Avatar
Same setup I use on my 65. Cut the hose to fit and installed the stainless spring in the hose.
cmefly is offline
post #10 of 13 (permalink) Old 06-13-2019, 06:44 AM
I believe it is a Dayco hose and it does have the internal spring to prevent kinking/collapsing.
Anangryford likes this.
post #11 of 13 (permalink) Old 06-13-2019, 07:52 AM Thread Starter
Thanks!
Chaplin is offline
post #12 of 13 (permalink) Old 06-15-2019, 03:40 PM Thread Starter
Ok, update:
I picked up another hose for a 70 with a 302 and, with some minor trimming, it did perfectly. The first 70 hose that they gave me must have been the wrong hose.
Thanks guys!
Chaplin is offline
post #13 of 13 (permalink) Old 06-15-2019, 04:23 PM Thread Starter
“fit perfectly”...
Chaplin is offline
